Results 1 to 15 of 18
11-10-2017, 09:50 AM #15000 RPM
- Jun 2002
- Northern Utah
- 454
- 7
- 24
Sportmaster 3.0L Water Pump Longevity
I've been having water pump impeller failures on my 3.0L sportmaster case. On my last replacement, I used the Merc kit that included new gaskets, shaft key, and housing bottom plate. It only lasted about 5 hours. The one before that lasted about 20 hours. In each case, the white keyed bushing comes loose from the impeller so it just slips on the drive shaft.
Anyone else having this problem? Any solutions?
11-10-2017, 09:57 AM #2
I have heard that there are different impellers.
plastic white bushing = fish motor
brass bushing = HP
I have some on the wall @ the shop, I will check. :-)Wriggleys gum makes me think of boating, "Double your engines, Double your fun"
davemvegas liked this post
11-10-2017, 10:59 AM #3
just looked at new on our wall in our show room. Hard plastic. There is no other part number for HP. 8M0100527
11-10-2017, 11:47 AM #45000 RPM
- Jun 2002
- Northern Utah
- 454
- 7
- 24
Thanks for the fast responses. Thats what I have found as well. There is only one type of impeller and it is used on many Merc engines. It has the white plastic bushing glued on to the rubber impeller. For me, the glue bond fails and the white bushing slips on the rubber impeller. I haven't heard or seem any posts with this problem.
Just bad luck on my part?
11-10-2017, 05:44 PM #5
11-10-2017, 05:49 PM #6
11-10-2017, 06:54 PM #75000 RPM
- Jun 2002
- Northern Utah
- 454
- 7
- 24
I think I may jumped ahead of myself. I lost water pressure yesterday just idling around for about 5 minutes. The same symptoms as last time when the plastic bushing spun on the impeller--zero pressure at idle and about 5-10 psi at all other RPMs. I assumed this happened again. I was wrong. I just pulled the water pump and found a very small amount of course sand in the pump. I also found some nicks in the impeller blades on the bottom edges. The plastic bushing was fine. Last week I idled through a shallow area but didn't think much of it. Since then, I've put a few hours on it with no problems then all of a sudden no pressure. I didn't see any more sand in the case but flushed it out anyway and put in a new impeller. I'll give it a try tomorrow.
Oh....my setup is a 21' Checkmate, 3.3 Yamaha w/ Hydro Tech mods, Sportmaster 1.62, usually run a mod'd Bravo prop even to 2" above the pad. It is only started in the water or on the hose...never dry.
11-10-2017, 06:58 PM #8
Your pressures sound like the norm on both my 250efi and my 300x. Maybe you expecting to much.
11-10-2017, 07:13 PM #95000 RPM
- Jun 2002
- Northern Utah
- 454
- 7
- 24
I don't think so. My water pressure is usually 2-4 psi at idle,
11-10-2017, 07:20 PM #10
well that is fantastic for a 3 liter at idle. Is that from a manual gauge or smartcraft?
11-10-2017, 07:23 PM #115000 RPM
- Jun 2002
- Northern Utah
- 454
- 7
- 24
I didn't get my post finished....
I don't think so. My over heat alarm went off when I was idling with 0 psi and very little water coming from the pee stream. My water pressure is usually 2-4 psi at idle, about 15 at slow cruise, 20-25 at fast cruise, and 12-15 trimmed and jacked up at speed. I've been using this setup for about 8 years. The gauge is manual using a tube.
NICE PAIR liked this post
11-10-2017, 07:30 PM #12
That is incredible water pressure for a 3.0 Mercury outboard. Lucky to see 10-12 lbs of water pressure at WOT in the many 200efi thru 300x's we service.
11-10-2017, 07:31 PM #13
Never mind, just noticed your running a Yamaha. I will go away now
11-10-2017, 09:18 PM #14
11-11-2017, 07:59 AM #155000 RPM
- Nov 2009
- hardyville va
- 367
- 7
- 38
- 43
2.5 sportmaster water pump
By michael lang in forum Technical DiscussionReplies: 7Last Post: 06-07-2017, 08:35 AM -
3L Sportmaster Water Pump
By lance in forum Technical DiscussionReplies: 1Last Post: 09-04-2014, 06:20 AM -
Mercury Tech: Sportmaster Water pump
By 4Speed in forum Technical DiscussionReplies: 9Last Post: 11-08-2011, 06:06 PM -
By maverick1 in forum Technical DiscussionReplies: 2Last Post: 06-30-2006, 04:05 PM
