Results 1 to 4 of 4
    May 2017
    St. Louis, MO
    1998 Yamaha VMAX 200 making horrible noise early in trim up
    Anyone know why my outboard trim would make a ugly scraping noise early on while trimming up? Air in the hydraulic chamber? I posted 2 videos so you can here exactly what it sounds like. Thanks in advance.
    Video 1:
    https://youtu.be/80K_RPuL2zE
    Video 2:
    https://youtu.be/bynWxgBZ-II
    Change fluid and purge yet?
    Mar 2015
    Southeast Texas
    Yeah it sounds like some air and possibly a little water got in there too. Which means you probably got a bad seal. Like FMP says...fluid change and purge will short term fix it. You could address the seal to keep that from happening again in the future...or just keep doing a fluid change and purge when it happens again until the frequency of that starts to get on your nerves.
    96 Bullet 20cc, Yamaha OX 250+, 10" jack, labbed 30" Bravo LH w/1.25" exhaust pipes, counter rotating Bob's lower...it goes faster when you spin it the other way...
    02 Dodge Cummins 2500 reg cab 4x4, converted long to short bed, up a foot, twins, injectors, fully built auto, dyno'd 582hp/1015tq
    99 Dodge Viper GTS Coupe, 8.0L V-10, lowered 1", Corsa pipes/no cats, 450hp/500tq
    Apr 2009
    Texas
    Try lubricating the tips of the trim rams and the socket they run against, use a heavy lube. Good luck
  1. 1998 yamaha vmax rev limiter
    By aaronmt73 in forum Technical Discussion
    Last Post: 08-10-2007, 11:48 AM
  2. Yamaha 225 vmax hydraulic trim ?
    By 93tmoore in forum Technical Discussion
    Last Post: 04-11-2007, 01:38 PM
