Results 1 to 3 of 3
Thread: Check your fuel pick ups
11-07-2017, 01:11 PM #1Supporting Vendor
- Jun 2008
- Maryville, Tennessee
- 1,019
- 28
- 28
- 49
- 258
I have been through several project boats over the last few years and have found a common problem I thought I would share. If you can access your fuel pick up it might not be a bad idea to check it. I have seen the filter screens collapsed/blocked, clamps loose on two piece units and then there is this little jewel that was the stock pick up out of an Allison aluminum tank. Notice the wire used to attach the rubber lower hose to the upper aluminum tube. Then, of course, check out what was going on to the lower, flexible piece. If you had your pristine, nik plated, high performance motor humming along at 7500 rpm and you ran it down below half a tank of fuel the results would be bad. Very bad. I am replacing all of mine with stainless steel tubes purchased through a heavy truck fuel tank supply house. Just cut them to fit. No filter screen. Use an inline filter right out of the tank and after the fuel pump.
Dave Hensley
1986 XR2002 /12" Mariner and string steering
18' Pugh Hydro
1992 XTB-21/225 ProMax
The barn is emptying out!!!
XstreamVking, Dave Strong thanked for this post
11-07-2017, 03:21 PM #2
good post
Glasstream15 thanked for this post
11-08-2017, 11:48 AM #3
Rusty clamp and wire? ethanol? My BAJA and Cougar have solid aluminum pick ups with screens. Good to know for other boats.
How to check fuel setting with DDT???
By h2oskiier30 in forum Technical DiscussionReplies: 4Last Post: 07-04-2011, 07:38 PM -
Help I there some way to check the octane of fuel
By schiadart in forum Technical DiscussionReplies: 3Last Post: 08-20-2004, 11:40 PM -
pick-ups in fuel tanks
By speed in forum Technical DiscussionReplies: 8Last Post: 02-16-2003, 03:02 AM
