Results 1 to 15 of 16
Thread: 1978 Mercury 140 Hp outboard
11-06-2017, 05:10 PM #1
1978 Mercury Outboard 140 HP serial number - 5094195
Motor is 20-inch midsection, distributor ignition, freshwatermotor from Missouri. Removed andreplaced rear water jacket cover and both interior and external exhaust baffle/water jacket covers. Replaced all fuel lines with new ethanol resistant fuel line, new fuel pump diaphragm and gaskets.Timing belt replaced. Carbs soaked and cleaned and reassembled with newgasket kits. Trigger wires were crusty so that was replaced with a much newerone. Already has CDI aftermarket internal wiring harness and stator so allwiring on this motor is in really good shape. Compression even at 125-130 in all 6 holes. Fuel bleed lines replaced with new tubing. No external crud orcorrosion on motor leg indicating it spent most of its life in fresh water. Has external twin ram power trim rams, hoses and pump with it. Trim Hoses show usualweathering but no visible leaks. Cowlings and wrap have no dents, weathered some but very useable as is. Cylinder block has no serial number stamped on it so was replaced at some point in the past.Lower unit was disassembled, cleaned,inspected and resealed with all new seals, replaced bent prop shaft, new water pump. Pressure tested and held 15 psi overnight . Skeg has a small ding out of it in the middle.Starts quick, crisp throttle response. Shifts gears smoothly.No prop,no gas tank, no controls included. Will test run and compression test for potential buyers.
$1400 – Located in Palm Bay, Fl.
11-12-2017, 02:29 PM #2
Bump- need this gone......
11-12-2017, 03:23 PM #3Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
That's a giveaway price, a Texas member was looking a couple days ago I think.
11-12-2017, 04:21 PM #4
That's a real nice one! GLWS
11-12-2017, 05:02 PM #5Member
- Nov 2010
- nort carolina
- 46
give me a jingle with contact to modonne7@aol.com
11-12-2017, 05:12 PM #6
This motor needs nothing except a boat and a home....
11-13-2017, 07:35 PM #7
Sent emails. Check your spam box please
11-14-2017, 01:42 PM #8
still available.
11-16-2017, 06:20 AM #9
Price drop ..... $1200. Need it gone.
11-16-2017, 08:17 AM #10Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Cocacola in Plano TX was looking, a while back.
11-20-2017, 12:19 PM #115000 RPM
- Jul 2009
- Liberty,tn
- 153
Tom, You just sold me the missile if I drag it over there can we mount it on the boat. If so 1100 cash?
Brian. Can be there Wed..
11-20-2017, 07:06 PM #125000 RPM
- Jul 2009
- Liberty,tn
- 153
I will take it 1200, can be there Wednesday. Sold I hope.
11-21-2017, 07:42 PM #135000 RPM
- Jul 2009
- Liberty,tn
- 153
Know you are probably doing Thanksgiving stuff, just let me know, I definitely want it, have cash, three hours away,please do not sell it to someone else, it will be going on your baby you restored.
Thanks, Brian
11-23-2017, 09:50 PM #14
11-25-2017, 04:46 PM #15
SOLD and GONE !!!!!
1978 Mercury 850 XS
By Mtnbike1 in forum Outboard EnginesReplies: 5Last Post: 05-11-2017, 08:30 AM -
1978 mercury 150
By warlock-871 in forum Outboard EnginesReplies: 2Last Post: 07-21-2014, 06:17 AM -
1978 Inline 6 Mercury Prop fit a 1986 Mercury 2.4 175?
By WSJR1 in forum Technical DiscussionReplies: 17Last Post: 07-31-2010, 03:51 PM -
1978 Mercury 175
By tombrown in forum Technical DiscussionReplies: 11Last Post: 07-26-2001, 04:25 PM
