Results 61 to 72 of 72
Thread: Mercury Rod Cap Alignment
11-08-2017, 12:32 PM #615000 RPM
- Dec 2003
- 190
Conventional type bolts? Meaning other than SPS, TTY or OEM? Sorry didn't register..
11-08-2017, 12:32 PM #625000 RPM
- Dec 2003
- 190
Where can I purchase the SPS Bolts?
11-08-2017, 01:00 PM #63
Sorry for not being clear. The OEM bolts are tty. All your performance bolts (SPS and ARP)are normal hardened bolts better suited for performance and won't give you that mushy feel when tightening and have very little stretch. The Performance bolts will be torqued without using any additional angles being they don't go into a plastic phase as the tty bolts do and can be used over and over. I get mine from pro-marine.
11-08-2017, 02:08 PM #64
Ya gotta slap me upside my head sometimes. I get to bablin on and don't make no sense sometimes. Ya just gotta reel me back in
11-08-2017, 02:26 PM #655000 RPM
- Dec 2003
- 190
Perfectly clear... Thanks much, I learned something new and absorb!
One more question related.. Is the manufactures name TTY and makes these bolts exclusively for Mercury? If so, can you purchase TTY Bolts outside of the Mercury markup?
11-08-2017, 02:28 PM #665000 RPM
- Dec 2003
- 190
Additionally, would you use SPS and/or ARP over TTY in all of your rod applications? I assume by your name your involved with auto engines as well as Outboard Motors.
11-08-2017, 02:49 PM #67
Tty (torque to yield) is just the type bolt ( high tech bolt designed to stretch at certain stress point) works great for production due to accuracy during torque process and in auto industry used them because they can use a smaller od bolt and less of them to save weight for economy. Problem with them in performance situations is under load you could exceed the point where it's designed to stretch. There are many companies that make the tty bolts, only one in aware of for Mercury is the oem bolts. I don't have a problem using them in stock applications, but prefer the non tty just (SPS seems to easier to find)
11-08-2017, 03:40 PM #68
Yeah, my profession is with autos. I don't know crap about an outboard, which is why I like em so much . In the auto industry it's filled with all kind of fasteners that you have to be well aware of for liability purposes. The real main reason the auto industry went to tty type bolts was weight savings, now they have taken it even a step further as to using aluminum bolts( also throw away bolts as you can imagine). In automobiles I prefer ARP, in marine they are a little harder to come by. SPS has been great and have no complaints
11-09-2017, 06:48 AM #69
Nope , the nuts never fell off . The bolts usually broke off at the shank / first thread junction . ( remember , I am talking circa 1975 on 1960's era BBC's )
In situations where you can measure the stretch then the spec will be to a stretch to a spec.
If you keep the stretch in spec you can reuse the bolt as you stay in the elastic zone.
Torque to yield goes into the plastic zone so its single use.
So if the bolt cant be pulled up to elastic or the quality doesn't warrant it then you find the spec says loctite etc or it has a spring washer etc.
11-09-2017, 07:33 AM #70Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
were you reving the bbc's over the original redline, shock horror?
11-09-2017, 08:26 AM #71
powerabout liked this post
11-09-2017, 04:25 PM #72
Just for info for anyone that cares or wondering why we even have the little tty bolts. If doesn't interest you or make you curious then ignore this post. The theory behind the tty bolts (theory is a fancy way for engineers to convince ya they need to be paid more) is that a standard bolt can only be torqued to 20% less than its yield rate without potential failure and tty bolt is torqued above its yield rate. This allows the manufacturer to use a size smaller bolt and sometimes fewer bolts to get the same clamping force ( I sometimes really wonder about this)to save weight. In mercury's rod bolt case I suspect it was more cost effective to use a tty bolt over a more expensive hardened bolt to get the needed clamping force of such a small diameter bolt. Figured I would throw that out there to help some understand the tty bolt more clearly and why in the world a manufacturer would use a "throw away bolt" in the first place.
powerabout thanked for this post
2005 Mercury 60 Throttle Cam alignment
By litespeed in forum Technical DiscussionReplies: 5Last Post: 10-22-2017, 01:06 PM -
Mercury Tech: Flywheel alignment
By low tide in forum Technical DiscussionReplies: 8Last Post: 02-23-2013, 11:32 AM -
Sleeve alignment
By blazer200 in forum Technical DiscussionReplies: 10Last Post: 02-15-2005, 04:10 PM -
2.4 Shift Alignment
By Splash105 in forum Technical DiscussionReplies: 0Last Post: 05-21-2004, 09:27 PM -
L/U Alignment
By T3Guy in forum Technical DiscussionReplies: 13Last Post: 10-03-2003, 09:00 PM
