Results 1 to 15 of 16
11-01-2017, 09:22 PM #1
re core or stringers and stiffeners on hydrostream valero, calm lake boat.
no interior just 2 bucket seats 12 gal tank n batt 94 225-250 3.0 bobs lwp and exhaust mod. ported and boyson reeds. 8' set back plate. i do have another post on same boat just diff questions. Thanks for your time and knowledge....
coffeeguy liked this post
11-02-2017, 06:17 AM #2
Is there a question??
11-02-2017, 06:40 AM #3Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
I like a core and floor on my boats. Just easier to walk around in it. If you want a true competition look and slightly less weight an open stringer set up would be the way to go. Really your choice, and based on how you plan on using it. Center dteer and fuel moved fwd tends to work well in a comp layout. Side steer works better with a floor. jm2cts
oldschoolnc thanked for this postoldschoolnc liked this post
11-02-2017, 09:19 AM #4
Having some form of flat surface is nice, plus sandwich panel is very light.
11-02-2017, 12:22 PM #5
This ^^^
Converting a lake boat into a comp is tedious and in the end won't be a whole lot lighter than the lake version (production version) vs a true comp boat is significantly lighter.
I "believe" the production boats are laid up heavier than the comp versions, my V-King is anyway.James H. W2F a V-King... Want 2 Fly a V-King
11-03-2017, 03:59 PM #6
Whats your VKing?? 370#s?
11-03-2017, 05:21 PM #7
Over here in uk we dont run boats with a core, we have strong stringer and keel set up.
it is much stronger than core, as most our boats are run in rough water (sea ) and a core would not stand up for too long.
we still have a floor from side to side and front to back etc, it is the strongest, but also heaviest construction.
BUT with a lot of American boats the thickness of the hulls is pretty thin and a core is needed to give the bottom its strength..
if your not going in rough water then a core is probably plenty good enough.
11-03-2017, 05:48 PM #8James H. W2F a V-King... Want 2 Fly a V-King
11-03-2017, 06:44 PM #9
I dont know what mine weighs... but it draws lots of attention when i do this
11-03-2017, 07:17 PM #10Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
11-06-2017, 01:00 PM #11
We have had some terrifically fast boat designs over here that would give anything a good run on a lake, but when the going gets tough so many of them
have failed the test.
Nothing compares to a strong built boat, ultra light are ok for calm lakes.
old school boats go out just about the same time as the new boats come in, so it realy is a matter of mega high speed or just very high speed that
decides how to build the boat.
I prefer a boat that can run over a big log and carry on, not one that will disintegrate like a grenade .
11-06-2017, 01:29 PM #12
Underestimating a core/stringer combination I think.
Lighter and stronger than production boats....on this side of the pond anyway. jus my 1/2 pennyJames H. W2F a V-King... Want 2 Fly a V-King
11-06-2017, 04:24 PM #13
After a 75 mph impact with a log this spring my cored boat shrugged it off and kept on it's way. Had to drill the impacted wood spilnters out of the water pick up holes in the gear case, and pull the seat cover out of my ass though.
rjdubiel, W2F a V-King liked this post
11-07-2017, 11:17 AM #14Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
11-07-2017, 03:58 PM #15
It was one hell of a ride.
Hydrostream Valero yt core questions
By blackbullet40 in forum General Boating DiscussionReplies: 1Last Post: 05-09-2017, 06:20 AM -
Hydrostream Valero YT - core, stringers and transom replacement questions
By Fullthrottleguy in forum Fiberglass and Composites DiscussionReplies: 31Last Post: 06-10-2013, 06:38 PM -
Greg's Hydrostream, No Core & 6 Stringers?
By WSJR1 in forum Fiberglass and Composites DiscussionReplies: 0Last Post: 05-30-2012, 09:46 AM -
hydrostream vandal core and stringers deck
By afr in forum Fiberglass and Composites DiscussionReplies: 20Last Post: 03-25-2012, 12:36 AM -
Hydrostream valero stringers
By fergie72r in forum Fiberglass and Composites DiscussionReplies: 3Last Post: 08-24-2011, 09:30 AM
