Results 16 to 17 of 17
Thread: 1999 Pro Max Questions
11-06-2017, 09:21 AM #16
I've got the wing plates for the XS motors. The steering came off my Pro-Max's. The single ram offshore pro-max leg has provisions for a wing plate right @ the bottom of the skirt.
The wing plates I used were single piece and they slide up on to the power head bolts. (cutting the lower bowls is a little spooky) there is a 3 piece wing plate set that would probably be a little easier to cut for and would leave more of the lower bowl intact. $ .02
Attachment 391552
Some of the more daring guys cut the entire lower part of the bowl off ... leaving their nuts exposed.Wriggleys gum makes me think of boating, "Double your engines, Double your fun"
11-06-2017, 09:25 AM #17Team Member
- Jun 2004
- long island
- 1,787
- 821
- 450
- 4251
- 4692
nice
thanks for the info!
1999 optimax 225 questions, compression numbers with 700 hrs
By seef158 in forum Technical DiscussionReplies: 1Last Post: 07-11-2014, 09:04 PM -
Mercury Tech: Interchange Trim unit between 1999 225 EFI and 1999 225 OPTI
By javiert99 in forum Technical DiscussionReplies: 2Last Post: 11-12-2013, 09:44 AM -
Mercury Tech: new 1999 xr6 150 owner questions
By shawn880 in forum Technical DiscussionReplies: 2Last Post: 10-12-2008, 07:55 PM -
1999 PM 300 questions
By fishead1 in forum Technical DiscussionReplies: 9Last Post: 05-11-2007, 03:46 PM -
1999 225 pro mag questions????????
By joey jamz in forum Technical DiscussionReplies: 7Last Post: 12-21-2004, 10:53 PM
