Results 1 to 8 of 8
Thread: Mid 80's Power Trim on 150
10-29-2017, 12:47 PM #15000 RPM
- Oct 2008
- Plainville, CT
- 799
- 417
- 22
- 377
- 65
Looking at a mid-80's 150 to buy. It appears the power trim pump is the old style one that goes inside the boat. I don't have room for that nor do I want the extra plumbing. Can I just change the transom brackets and add the new style power trim unit that goes right on the brackets?
10-29-2017, 02:40 PM #2Screaming And Flying!
- Dec 2001
- 9,503
- 270
- 191
- 1975
Every thing is different.... see guy that wants to know weight diff maybe ya can swapo...
10-29-2017, 03:45 PM #36000 RPM
- Dec 2011
- Ottawa
- 1,365
- 33
- 47
- 20
- 72
Yes you can swap a newer 2 or 3 wire, 3 ram clamp and TT onto your old can. use your 150 adapter plate and tuner
10-29-2017, 03:54 PM #4Screaming And Flying!
- Dec 2001
- 9,503
- 270
- 191
- 1975
Read his post again... hoses not wires....
10-30-2017, 07:37 AM #5
You will need to swap the entire clamp bracket, trim unit and swivel bracket....including the swivel pin & yoke. Keep your can, mounts and 2 pc adapter
Go Time
26 Regulator twin 250 EFI
10-30-2017, 08:13 PM #65000 RPM
- Oct 2008
- Plainville, CT
- 799
- 417
- 22
- 377
- 65
Oh the swivel too. I didn't think of that. OK, thanks. Didn't buy yet, still considering. The motor will need other work too, but the compressin is supposed to be OK.
10-30-2017, 08:30 PM #7
150 two liter? They are heavy, but run like a clock. If you are weight sensitive, I would look for a newer 135. Roughly the same HP and they have the integral trim.
10-31-2017, 07:15 AM #85000 RPM
- Oct 2008
- Plainville, CT
- 799
- 417
- 22
- 377
- 65
That would be less work for sure.
Mercury 115 Tower of Power power trim
By baja030 in forum Outboard EnginesReplies: 14Last Post: 11-11-2017, 11:16 AM -
Aftermarket trim: Panther power trim and tilt bracket opinions?
By mxz in forum General Boating DiscussionReplies: 4Last Post: 10-28-2016, 06:05 AM -
InLine Merc Racing Quik trim power trim rams
By Tom Smyth in forum Parts WantedReplies: 0Last Post: 12-05-2015, 02:22 PM -
40 hp-60 hp power trim conversion from manual trim.
By AlaskaStreamin in forum Props, Setup, and RiggingReplies: 15Last Post: 12-10-2004, 01:42 PM
