Results 1 to 7 of 7
    Oct 2017
    Port St Lucie
    Detecting Bulkhead/Stringer issues by a Vertical Line Paint "Reflection" of Hull?
Name:	issue with hull from paint.png
    I'm looking at purchasing this older boat - its from the 80's its a Magnum from Don A.
    When looking Down the port side from bow you can see a vertical line from where the paint is "Bending" or has "Reflected".
    Has anyone any experience in this - know if this is from a Structural Issues within the hull or just a bad paint job?
    Boat is a 27' - please open pics to FULL SIZE and you will see the "wrinkle" in paint from the air vent downward.
    Thanks
Name:	vertical issue with Mag 27.jpg
    There might be a bulkhead touching the hull at that point causing the bulging line you see going going from rub rail to chine. Look inside and see if there is one there. Not uncommon on older boats to have that kind of line. 2nd possibility is a repair, but I would bet it's the bulkhead printing thru. How about the other side in the same place? Any lines there?
  3. Likes Noah Burns liked this post
    Oct 2017
    Port St Lucie
    Thx for the feedback - no, no other lines on the starboard side - just that single line on the port side in the pic -
    haven't been inside her - but will shortly when i craft an offer pending any issues...
    thx again.
    Jan 2007
    Amityville/Lindenhurst
    thats nothing drop by any new boat dealer and check out the hullsides
  6. Likes Murph, NICE PAIR liked this post
    Sep 2008
    Treasure Island Fl
    Its called a "hard spot" It is common on older performance boats. It is where a bulkhead is. Modern hulls usually have cored hull sides which prevents hard spots. I would worry about it.
    Cawley
    NJ
    Just curious if you bought the boat? I saw this boat about a month ago when visiting Stuart. What speed are they getting with this set up?
    Mar 2015
    DFW
    I've seen dried up/rotted transoms that were obvious in older boats but that's about it... in the side of a hull it would be pretty hard to tell visually like that I would think. Have you gotten in the boat, does it feel stout? tap on the surfaces, listen for different sounds etc.
  1. Replies: 2
    Last Post: 09-02-2013, 10:41 PM
  2. 20" mid on a 15" STV Transom? Jackplates with enough vertical rise?
    By JRider in forum Props, Setup, and Rigging
    Last Post: 05-16-2012, 06:29 AM
  3. Cap,Hull Split Line, Rub Rail Issues
    By Liberator*21 in forum Fiberglass and Composites Discussion
    Last Post: 06-25-2010, 05:15 PM
  4. Mercury Tech: Converting 20" to 15" Vertical Shaft
    By oledawg in forum Technical Discussion
    Last Post: 08-19-2009, 08:46 AM
  5. Stringer and bulkhead question
    By Perfect-Storm in forum Fiberglass and Composites Discussion
    Last Post: 01-25-2004, 11:02 AM
