Results 1 to 7 of 7
10-26-2017, 07:18 AM #1Junior Member
- Oct 2017
- Port St Lucie
- 11
Detecting Bulkhead/Stringer issues by a Vertical Line Paint "Reflection" of Hull?
I'm looking at purchasing this older boat - its from the 80's its a Magnum from Don A.
When looking Down the port side from bow you can see a vertical line from where the paint is "Bending" or has "Reflected".
Has anyone any experience in this - know if this is from a Structural Issues within the hull or just a bad paint job?
Boat is a 27' - please open pics to FULL SIZE and you will see the "wrinkle" in paint from the air vent downward.
Thanks
10-29-2017, 12:38 PM #2Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
There might be a bulkhead touching the hull at that point causing the bulging line you see going going from rub rail to chine. Look inside and see if there is one there. Not uncommon on older boats to have that kind of line. 2nd possibility is a repair, but I would bet it's the bulkhead printing thru. How about the other side in the same place? Any lines there?
Noah Burns liked this post
10-30-2017, 07:36 AM #3Junior Member
- Oct 2017
- Port St Lucie
- 11
10-31-2017, 04:20 PM #4Scream And Fly VIP
- Jan 2007
- Amityville/Lindenhurst
- 3,012
- 46
- 18
- 204
thats nothing drop by any new boat dealer and check out the hullsides
Raybo Marine http://www.raybomarine.com/
01-14-2018, 08:46 PM #5
Its called a "hard spot" It is common on older performance boats. It is where a bulkhead is. Modern hulls usually have cored hull sides which prevents hard spots. I would worry about it.
Cawley
01-17-2018, 07:51 PM #65000 RPM
- Sep 2003
- NJ
- 656
- 11
- 91
- 21
Just curious if you bought the boat? I saw this boat about a month ago when visiting Stuart. What speed are they getting with this set up?
01-17-2018, 11:04 PM #75000 RPM
- Mar 2015
- DFW
- 665
- 16
- 42
- 366
- 232
I've seen dried up/rotted transoms that were obvious in older boats but that's about it... in the side of a hull it would be pretty hard to tell visually like that I would think. Have you gotten in the boat, does it feel stout? tap on the surfaces, listen for different sounds etc.
1983 21 Sanger "classic" OB with Merc 225 engine and stringer transom rebuild/Resto.
By Zoomba in forum Technical DiscussionReplies: 2Last Post: 09-02-2013, 10:41 PM -
20" mid on a 15" STV Transom? Jackplates with enough vertical rise?
By JRider in forum Props, Setup, and RiggingReplies: 9Last Post: 05-16-2012, 06:29 AM -
Cap,Hull Split Line, Rub Rail Issues
By Liberator*21 in forum Fiberglass and Composites DiscussionReplies: 2Last Post: 06-25-2010, 05:15 PM -
Mercury Tech: Converting 20" to 15" Vertical Shaft
By oledawg in forum Technical DiscussionReplies: 2Last Post: 08-19-2009, 08:46 AM -
Stringer and bulkhead question
By Perfect-Storm in forum Fiberglass and Composites DiscussionReplies: 1Last Post: 01-25-2004, 11:02 AM
