Results 31 to 45 of 50
Thread: Hydraulic Side Ram Steering
12-03-2017, 03:42 PM #31
The pro helm is valved differently is why teleflex says if doesn't work.
12-03-2017, 04:59 PM #32
Here this explains the ram.
The answer is in the design of an unbalanced cylinder.
When the helm is turned one turn, a certain volume of fluid is pumped into the cylinder.
On one side of an unbalanced cylinder piston is a rod, which reduces the effective cylinder volume.
The cylinder area on the other side of the piston has no rod, thus more volume available for fluid pumped in from the helm.
The piston side with the rod will move farther per turn of the wheel (less turns to hard over) because less space is available for the fluid than the side with no rod.
A balanced cylinder has a rod on each side of the piston, so will move equally to either side per wheel turn to that side.
(See diagrams below.)
99fxst99, wetsetmarine liked this post
12-03-2017, 05:10 PM #33
This is the warning from SeaStar site, doesnt explain why
WARNING:
SeaStar PRO Steering Helms can not be used with an unbalanced steering cylinder.
12-03-2017, 05:15 PM #34
12-03-2017, 06:49 PM #35
on mine yes. couple turns but only when going slow
12-03-2017, 07:22 PM #36
Twin rams alleviate this?
12-08-2017, 04:35 PM #37Scream And Fly VIP
- Jul 2013
- California
- 1,555
- 21
- 63
- 83
- 294
12-08-2017, 09:33 PM #38
01-17-2018, 12:45 PM #39
Any interest in the steering components? They are still for sale.
Triad V21 #002 - 15in DBR 300 xs
19' J-Craft - 175 Opti
18' Pontoon - 115 CT 4S
01-21-2018, 12:56 PM #40Member
- Apr 2017
- key largo florida
- 41
- 10
I am currently having the issue where my 2.4 helm isn't holding enough fluid.. I think the quoted answer would solve my issue but I don't seem to understand how to set this up.. does the reservoir have to be mounted above the helm? What reservoir should I use? and what plug do I take out off the back of the helm?
01-21-2018, 07:31 PM #41
Take the plug out that is at 12 o’clock looking at the back of the helm. Put a barb in there and run a hose to a remote reservoir above the helm. I used pvc with end caps but a couple different things like a mercruiser drive oil reservoir will work perfect. Just make sure it’s vented and plug the helm vent off with the plug you remove from the rear of he helm.
01-21-2018, 08:38 PM #42Member
- Apr 2017
- key largo florida
- 41
- 10
vnemous liked this post
02-17-2018, 08:10 AM #43
$1500.00
Bump...steering components still available.Last edited by V-bottom; 02-20-2018 at 07:35 AM.
02-21-2018, 09:08 PM #44
Deposit received. Thanks S&F
02-21-2018, 11:15 PM #45Team Member
- Apr 2014
- nj
- 496
- 16
- 115
Come to papa
Who is using side-mount hydraulic steering?
By STV_Keith in forum General Boating DiscussionReplies: 5Last Post: 02-01-2007, 10:25 AM
