Results 1 to 15 of 16
Thread: Mercury Verado Pro Owner Reviews
10-23-2017, 09:02 PM #1Member
- Mar 2004
- Barrie, Ontario
- 36
Looking at purchasing at the Toronto Boatshow so I'm doing my research now. The Campion 600 bowrider is what we are thinking about and can handle up to 300hp outboard. The outboard we are considering is a Mercury Verado Pro series. 200 250 or 300. Im looking for input on the engine pros and cons. Owner reviews as well.
Thanks.
10-23-2017, 09:18 PM #2
Oil contamination is a big issue with verados,particularly in cool water and lots of idling. So your better off halving the oil change intervals if you don't run them hard for hour(s) at a time.
10-24-2017, 04:35 AM #35000 RPM
- South Africa
- 575
- 7
- 30
I am sure that most of that issue is created by Mercury not using a break in oil, and running a synthetic or semi-synthetic oil from the beginning
If I were to buy a new motor I would drain the oil and run a break in oil for the first 20 hours do an oil and filter change run break in oil again for 30 hours and then change oil again, but change to a good oil. I would only fill it to the half way mark on the dip stick and then change oil every 12 months, 100 hours or if the dip stick got to the full mark, which ever occurred first.
Do not think changing oil very regularly is an issue, cost of oil and filter is minimal and is very easy to drain out or suck it out, no need to get a dealer to do that.
10-24-2017, 05:36 AM #4
Only oil contamination issues Ive seen is when the thermostat fails or you prop the motor too high and lug the engine. Also when changing the oil always run the oil level at the middle to lower part of the hash marks on the stick. Aside from that IMO you will love the engine!!
10-24-2017, 07:36 AM #5Member
- Mar 2004
- Barrie, Ontario
- 36
The engine will purely be recreational. Tubing, crusing around. Basically its a cottage boat. I do want to do some high end blasts around the lake too.
Would the 2018 engines have this contaminant problem? Is Mercury aware of the issue? what causes this contaminant issue?
10-24-2017, 08:17 AM #6
Lack of oil temperature.
10-24-2017, 11:09 AM #7
Not to derail the discussion but have you considered an Etec G2? Being built and used in Canada would lead me to at least look at all the options.
Mark
10-24-2017, 01:06 PM #8Member
- Mar 2004
- Barrie, Ontario
- 36
Yes its is for sure an option! also so is the Yamaha Vmax 200 250 HO.
10-24-2017, 03:51 PM #9
I run a Verado Pro 300 on a Checkmate 2400 Bowrider with an Atlas 8" hyd. jackplate and a Mercury Bravo One 24 pitch prop. 1 person on board with 1/2 tank of gas at 71+ mph GPS. The motor is quiet, idles smooth, shifts like a dream and the power steering is nice to have. After years of playing with dinosaur 2-strokes, the Verado is a nice change of pace. They also have tons of torque for heavy loads. Highly recommended!
J-Town Hot Boat Team
Barracuda 188CCR/Suzuki 140
Past Boats:
Checkmate 2800SX/Twin Merc 250’s
Checkmate Pulsare 2400/Verado 300
Checkmate Starflite/Merc Pro XB250
Canadian Edition Hydrostream AE-21/Merc 2.5
Checkmate Pulsare 2100/Merc 225Xri
Hydrostream Valero YT Bowrider/Merc 175
Talon T-21/Mercury Racing 2.5 Carb
Sleekcraft ModVP Bowrider/Evinrude 225 Vindicator
Velocity 230/Mercury 454 Magnum
Scout 172 Sportfish/Yamaha 130
SeaRay F16 Jet boat/Mercury SportJet
SeaRay 17' Seville/Merc I/O
10-24-2017, 04:12 PM #106000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
The issue with oil dilution is inherent to all four stroke outboards. It has to do with people that want to idle around all day, have thermostats that are not in good working condition, and low water temperatures. The engine and engine oil never reach proper operating temperature and therefore doesn't have a chance to burn off the gas that makes it past the Rings.
10-24-2017, 04:17 PM #115000 RPM
- Mar 2017
- Miami, FL
- 358
- 10
- 47
No issues with oil contamination on my triple set of 300 verados. 1200 hours with a lot of idling. I make sure to run them hard after idling for a while. After going verado you'll want one on all your future boats
10-25-2017, 09:12 AM #12Member
- Mar 2004
- Barrie, Ontario
- 36
Thanks for the input guys. I appreciate it.
10-25-2017, 10:01 AM #13
There is big difference in water temps between northern us/canada than florida.
10-25-2017, 04:22 PM #146000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
10-25-2017, 06:23 PM #15
The new Yamaha 4 stroke vmax motors were having the same exact problem with oil multiplication. They attributed it mostly to improper break-in...rings not fully seated yet. I've heard the problem goes away after the motor gets run in and rings get comfortable. Also heard that they caution against excessive idle during the break-in period for that reason. Low oil temps/cold water temps coupled with excessive idle makes perfect sense as well since cooler metal is smaller. Like RS said...looks like all 4's will have to deal with it.
Still love my loud, hard shifting, hard steering, gas and oil guzzling, ozone killing, mosquito deterring 2 stroke...96 Bullet 20cc, Yamaha OX 250+, 10" jack, labbed 30" Bravo LH w/1.25" exhaust pipes, counter rotating Bob's lower...it goes faster when you spin it the other way...
02 Dodge Cummins 2500 reg cab 4x4, converted long to short bed, up a foot, twins, injectors, fully built auto, dyno'd 582hp/1015tq
99 Dodge Viper GTS Coupe, 8.0L V-10, lowered 1", Corsa pipes/no cats, 450hp/500tq
Capt.Insane-o, NICE PAIR liked this post
Twin 1988 Mercury 175's Original owner
By Jessesouthfla in forum Outboard EnginesReplies: 5Last Post: 04-24-2016, 05:57 AM -
TH-MARINE Hole shot plate for jackplate Any owner Reviews???
By Djohns in forum Props, Setup, and RiggingReplies: 9Last Post: 10-30-2010, 07:42 AM -
Mercury Tech: New Hydrostream Owner & First Time Outboard Owner Questions
By TripleJackInGA in forum Technical DiscussionReplies: 24Last Post: 06-19-2009, 02:59 PM -
Mercury Marine and Mercury Racing Product Report: 300 Verado, 200 I-4 Verado, 1200SCi
By Scream And Fly in forum General Boating DiscussionReplies: 68Last Post: 02-21-2007, 07:56 AM -
Documentary: Life of a Mercury owner
By Markus in forum General Boating DiscussionReplies: 23Last Post: 10-05-2005, 09:38 PM
