Results 1 to 13 of 13
    Apr 2015
    Oceanside, NY
    1996 Twin Mercury 225 efi bad alternators
    Took the boat out the other day for a ride, motors were running poor, looked down and I was at 9 -10ish volts. Luckily I had a spare battery that i tossed in and was able to get home just fine. After a little diagnostic work i noticed that both alternators were dead.
    What could possibly kill both alternators? could it be a short or power loss somewhere? Batteries are not losing voltage when switch is left on so I am guessing there is no short but who knows.
    I found the alternators I need on amazon part number 821663a1 for 80 bucks which is a quarter the price I got quoted from a merc dealer. I just don't want to put these things in to have them blow up again.
    What kind of batteries are you using?
    Are these the small, Nipon Denso alts?
    I have used DB electrical ones i got online with no issues. Unfortunately they are all made in china...One alt. may have been bad for a while and the other just went bad and you had low volts. If your batts were hooked together one motor would charge them both.
  4. Thanks Seanj85 thanked for this post
    If you turn the battery switch's from one to the other and back again as a test or for whatever reason while the motors are running , it will spike the regulators and kill them .... dead .
    Moral of the story , find an old guy generator shop . He will fix them for $35.00 each. Everyone else want's $350.00 to fix yours or to sell you new ones .
    After that , use a battery load tester and a VOM for any further experiments .
  6. Thanks Seanj85 thanked for this post
    Likes NICE PAIR liked this post
    Apr 2015
    Oceanside, NY
    Batteries are a little small, they are 24 series. One passed a load test while the other failed. Think I am going to upgrade to 27's since the alternators charge at 100 amps total. They are the stock alts from the factory, not sure if they are Nipondenso
    Apr 2015
    Oceanside, NY
    Both are selected to all and I believe they have never moved but I cant really remember... There are 2 batteries with 2 switches, not sure how it is wired up, is this normal for twins?
    New alts and new batteries and check all the connections and switches for proper operation. Then your good to go for a while.
    Mar 2011
    Virginia
    The switches should not be left in the ALL position....this probably is part of the problem. Each switch should be selected to the battery designated for that engine ( stbd engine to battery 1 & port engine to battery 2). The ALL position cross connects the batteries and alternator outputs, and when a problem occurrs, it affects the entire electrical system and defeats the advantages of having redundant systems.
    Go Time
    26 Regulator twin 250 EFI
  11. Likes NICE PAIR liked this post
    Quote Originally Posted by Go Time View Post
    Agreed, I went extra measures to separate my motors into two separate systems so they do not affect each other.
    I also ran a bat 1/bat 2 leg to a left/right switch for all my accessories not controlled by their respective motor.
    Should I have to shut down a side to come in on one, I can choose which battery my accessories run off of.
  13. Likes Go Time liked this post
    Quote Originally Posted by Seanj85 View Post
    I had run some of the mini batteries in the past and they didn't like the 50 amp charge rate of the Nipon-Denso Chinese copies.
    After loosing 2 sets of alts and 2 sets of batteries, I went back to wet cell group 24 batteries and had no more problems.
    It sounds like you took out the systems by having them tied together @ all times.( the bad side takes out the good side)
    Mar 2011
    Virginia
    Nice Pair, I added a "hotel loads" switch as well...when trolling in my fishing boat with one engine, it allows me to run the boat off the operating engine and maintain segregation.
    Go Time
  16. Likes NICE PAIR liked this post
    Apr 2015
    Oceanside, NY
    Alright, put everything in last night after work. The 75 dollar amazon alternators are working great and charging at speed just over 14 volts. I traded in the old 24 series for 27 deep cycles from costco. They are interstates and were only 75 each, at 650 Cold cranking amps each they are a little light but seem to do the job fine. I replaced the belts and switched each battery to their respective engine. If I had bought everything from the marine store here in LI I would have spent over 1000 bucks, but shopping around I did it for 340.
    One old alternator was definitely burnt, and the other looked ok but probably blew the rectifier.
    Thanks for the help guys, this is a great forum.
  18. Likes NICE PAIR liked this post
  19. #13
    Mar 2011
    Virginia
    We have local shops than can replace the regulators pretty cheap. Look around, you may be able to repair it.
    Go Time
  1. 1996 Eliminator Daytona 21 DCB Rigged Twin Mercury Racing 2.5 260's!!
    By millertime83 in forum Hulls larger than 20'
    Last Post: 03-07-2017, 07:28 PM
  2. Twin 1996 Mercury 225 Carb 3.0 liter Outboards
    By nick28 in forum Outboard Engines
    Last Post: 01-14-2017, 07:42 PM
  3. Twin 250 efi mercury 1996
    By Tipitina in forum Technical Discussion
    Last Post: 08-07-2013, 06:50 AM
