Results 1 to 3 of 3
10-21-2017, 08:15 PM #15000 RPM
- Oct 2015
- Kentucky lake
- 480
- 31
- 15
- 60
Switching from carb to EFI questions
Wat options does a guy have to switch a carbed Bridgeport to a EFI system does it have to be horn style with the correct front half? Or can it be a fishing motor system confessed on the rpm limits and fuel tunning!! I run in the 7500 area
10-22-2017, 10:45 AM #2
A laser/promax style with a vst delete and your current efi pump with and adjustable regulator will get ya where you want to be with a little tuning.
'95 STV "The Blue Goose"
Dave Strong liked this post
10-22-2017, 12:55 PM #3
Can't go horn unless you get a different ft half. Laser EFI as said above.
2.4 carb questions
By seef158 in forum Technical DiscussionReplies: 3Last Post: 04-11-2013, 10:35 AM -
V8 Questions about switching from 4.0 Heads to 3.6 Heads
By rockman69 in forum Technical DiscussionReplies: 6Last Post: 09-08-2011, 11:11 PM -
Mercury Tech: Switching from 225 carb to 250 EFI???
By rchevelle71 in forum Technical DiscussionReplies: 4Last Post: 08-05-2009, 06:46 AM -
Switching efi to carb on 3.0 Merc
By Da Bull in forum Technical DiscussionReplies: 6Last Post: 08-08-2008, 07:50 PM -
more carb questions
By TTriton in forum Technical DiscussionReplies: 10Last Post: 10-03-2001, 11:36 PM
