Results 1 to 10 of 10
    Mar 2016
    ok
    Question Mariner 225 Magnum TPS Diagnose
    96 Mariner 225 magnum efi.
    While testing the TPS I have 4.75 volts going in on the blue and yellow wire.
    With key on throttle closed I have 3.76 volts coming out on the blue with red wire. (Should be 0)
    With key on press the throttle slowly volts drop to
    .74 volts. (Should increase)
    Does this indicate a bad TPS?
    Did you disconnect the 2 tan/blk head temp wires? Do you have the 91-816085 TPS test harness?
    Mar 2016
    ok
    Quote Originally Posted by Dave Strong View Post
    Did not disconnect tan and black wires but will and retest. Home made test connection.
    Have to disconnect those wires, tool is cheap and works great. That TPS is expensive don't want to miss diagnose.
    Mar 2016
    ok
    Is the test lead a dealer item? Ebat?
    Not sure about eBay, got mine from a dealer.
    Mar 2016
    ok
    Checking eBay now
    Mar 2016
    ok
    Quote Originally Posted by doalldoo View Post
    Checking eBay now
    Retested with test lead and tested ok. Fuel pressure is 36 one the muffs. Compression is 85, 85,85 on port side. 80,85, 90 on starboard side. Spark good on all 6.
    Compression way low. Get a different gauge and retry.
    Mar 2016
    ok
    Ok will do
  1. Mariner Magnum VS Regular Mariner
    By XstreamVking in forum Technical Discussion
    Last Post: 09-02-2010, 07:08 PM
  2. 98 Mariner Magnum 175 EFI
    By MarkMuzzy in forum Technical Discussion
    Last Post: 04-14-2010, 10:17 AM
  3. Mariner 3,0 lit magnum EFI
    By ae23 in forum Technical Discussion
    Last Post: 02-17-2008, 03:08 PM
  4. Mariner 150 Magnum II
    By MarkS1234 in forum Technical Discussion
    Last Post: 02-26-2007, 06:16 PM
