Results 1 to 6 of 6
    Jun 2001
    Cromwell. NEW ZEALAND
    3 litre merc experts
    New to modifying the 3 litre block. I have a brand new 225 optimax block. Would it make a good candidate for a performance engine? I believe these blocks have an exhaust chest like the 300x block. Advise please. Popey
    Popey
    Nope. The X motor has a less than ****ty chest than the Podunk motors. The opti blocks work fine, just some intricate cutting is involved.
    north myrle beach
    Get yourself a 250xb. It doesn't have exhaust relief slots like the 225 efi and the 300 pro max block.
    Quote Originally Posted by Steve Pope View Post
    That's a good block to start with . Late model sequential Motorola EFI electrics bolt right on . As do EFI heads and 300x reed plate .
    The ports are small , which to me is a plus . This way you can cut them how you want . ( I would rather have material in my way , than look for it and not be there)
    Only an X has the larger , less restrictive log. All others have the small passage . But that doesn't matter , it can be made to perform .
  5. Likes Capt.Insane-o liked this post
    Jun 2001
    I have always considered the 3 litre engine had potential as a low stress stump puller but never had much to do with them until just recently. Always worked on high stress 2.5 f1s. I will use this 225 opti block? I have no other parts yet so I can source whatever parts are more desirable to use. If the exhaust is more restrictive than the x block does that dictate not to copy the x porting. I have a customers x powerhead down at the moment (broken crank through number 6 crankpin) so I could get port sizes and timing if required. Thanks for the replies. Popey
    Popey
    Mar 2006
    auckland new zealand
    Popey welcome to the 3.0l merc. the block you have is great to start with like chaz and the others have said. I have modded a few and if you want to have a chat some time. we have meet b4 at race meets via luke sharp and malc.
  1. Need help from you Merc experts.
    By Dominator Scott in forum Technical Discussion
    Last Post: 08-30-2015, 08:34 PM
  2. Merc experts: need some info
    By brpdk945 in forum Technical Discussion
    Last Post: 11-20-2007, 02:01 PM
  3. calling on 2.5 Merc Experts!!!!
    By mousamlakespeedster in forum Technical Discussion
    Last Post: 07-17-2006, 04:18 PM
  4. Question for Merc EFI experts
    By Matt in forum Technical Discussion
    Last Post: 05-26-2001, 12:37 AM
