Results 1 to 4 of 4
    Oct 2017
    Western NY
    1996 Mercury 200 EFI oil pump removal
    Hi Folks, I've done an oil pump removal on my '96 Merc EFI and the only thing I'm hung up on is the electronic side of it. Everything I've read says to "remove the module". Would that be the warning module? Doesn't that control other warning systems? And I'm not sure what to do about rotational sensor either. Pics would be great. Thanks for any help. BTW I've been on this site countless times but just became a member. Love the info and site in general!
    Pekin, IL
    Remove the pump, shaft, sensor, and module (follow wires from sensor). Replace pump with correct block off kit. Do not just cover hole as there is a bushing down in the block that must be secured or it can come loose and wreak havoc. Mix oil in gas and go boating. Welcome to the site.
    Rock
    Team Junk
    Oct 2017
    Western NY
    Thanks for the quick reply. What sensor are you referring to? The one in the oil res? Doesn't the module control other warning systems? Like water temp and the rotational sensor? Thanks again
    Pekin, IL
    The sensor near the oil pump. Take the oil reservoir away being you don't need it. There are other modules warning modules for other issues.
    Rock
    Team Junk
  1. mercury outboard oil pump removal
    By terry1 in forum Technical Discussion
    Last Post: 05-13-2015, 08:54 AM
  2. 1996 merc 200 efi oil injection removal.
    By Edfrith in forum Technical Discussion
    Last Post: 03-28-2013, 09:50 AM
  3. 1995 Mercury 40HP 4 cylinder Oil Pump Removal Questions
    By rustnrot in forum Technical Discussion
    Last Post: 01-17-2012, 10:20 PM
  4. OMC V6 fuel pump removal
    By Lockjaw in forum Technical Discussion
    Last Post: 11-07-2005, 08:01 PM
  5. oil injection pump removal
    By Richard in forum Technical Discussion
    Last Post: 11-15-2002, 06:14 AM
