Results 1 to 6 of 6
10-19-2017, 09:12 AM #16000 RPM
- Dec 2011
- Ottawa
- 1,365
- 33
- 47
- 20
- 72
98 300 promax 4 hole butterfly injection
Is this the same part# as the late 225 and 250 efi's used ? Or is 300 different somehow ? Tks
10-19-2017, 12:11 PM #2
250 and 300 are the same part number. 225 was not available with 4 hole hence different part number. JMO
10-19-2017, 02:33 PM #36000 RPM
- Dec 2011
- Ottawa
- 1,365
- 33
- 47
- 20
- 72
Ok tks, ya your right most 225 had 2 hole, just wanted to make sure i could use the 300 4 hole on a 225
10-19-2017, 06:48 PM #4
you could even use it on a 3 liter 200efi add computers and wa laa you got a 250efi
10-23-2017, 07:13 AM #56000 RPM
- Dec 2011
- Ottawa
- 1,365
- 33
- 47
- 20
- 72
Tks i already have 250xb and 300 ecu's ,300 pm mid,tuner ,heads and cowling. sending a 98 225efi to machine shop for rebuild and re sleeving anything that dont come into std. Bore specs,
10-27-2017, 04:52 PM #6
The last of the 2 ecu 225s had the 4 hole intake also.
Popey
