Results 1 to 7 of 7
10-17-2017, 08:54 PM #15000 RPM
- Feb 2013
- Northern Cal
- 190
- 18
- 37
Lifting horizontal motor off shipping crate
I just bought a Merc V6 motor that the owner shipped to me mounted clamp side down on a factory metal shipping crate . Seems to me lifting off the crate with a lifting ring would put stress on the end of the crank shaft before transitioning to a vertical position to put on an engine stand . What is the best way to rig up the motor to get it off the crate safely ?
10-17-2017, 09:27 PM #2
It will be fine if you have your ring installed properly (bottomed out). Your main concern will be on the other side where the skeg is. Don't want it resting on the ground while the ring is going up. Luckily it's lighter on that side so a buddy can hold it off the ground while you are pumping the cherry picker.
96 Bullet 20cc, Yamaha OX 250+, 10" jack, labbed 30" Bravo LH w/1.25" exhaust pipes, counter rotating Bob's lower...it goes faster when you spin it the other way...
02 Dodge Cummins 2500 reg cab 4x4, converted long to short bed, up a foot, twins, injectors, fully built auto, dyno'd 582hp/1015tq
99 Dodge Viper GTS Coupe, 8.0L V-10, lowered 1", Corsa pipes/no cats, 450hp/500tq
10-17-2017, 09:28 PM #3
Lift up the shipping crate and lock upright if possible.
Otherwise, lifting ring in the flywheel won't hurt. You're only lifting half(ish) of the total weight in a horizontal position.1) 1995 14' Bayliner Restoration <--Click
2) Home-Made Tunnel-Boat Project <--Click
10-17-2017, 10:12 PM #4
Leave it attached to the shipping crate to protect the skeg while lifting. Lift with proper lifting ring screwed into the flywheel. Once vertical, remove the shipping crate. The factory manual tells you to do it this way.
10-18-2017, 05:24 AM #55000 RPM
- Feb 2013
- Northern Cal
- 190
- 18
- 37
Awesome thanks for the info everyone !
10-18-2017, 05:31 AM #6
Clamp down is the correct way. Like mentioned above, lift it with the crate attached!
I you are using a cherry picker it may get a bit tricky at a certain point, best to use a small piece of strong rope or chain to be able to move it or spin it if necessary.
10-19-2017, 04:44 PM #7Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
Merc cranks just break if a jonstone makes a big wake.....
outboard shipping crate
By Slowroll in forum Misc. Parts and AccessoriesReplies: 0Last Post: 01-08-2014, 10:02 PM -
powerhead shipping crate
By team supra in forum General Boating DiscussionReplies: 5Last Post: 08-29-2012, 04:08 PM -
Motor Shipping Crate Advice
By David L in forum Technical DiscussionReplies: 5Last Post: 08-13-2010, 05:26 PM -
Powerhead Shipping Crate Pic's
By RB in NM in forum General Boating DiscussionReplies: 9Last Post: 03-30-2006, 06:23 PM
