Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 31 to 45 of 62
  1. #31
    Chaz, your photoshop skillz are getting pretty good. That trellis bigger than usual? Billet addition is a nice touch as well..
  2. #32
    Nov 2002
    MCHENRY, IL/LOTO
    Great pics!!! Later, Dave
    2018 South Bay 3.0+ Tritoon W/Merc 400R
    2019 Wright Perfomance 36, twin Merc 400R's
  3. #33
    Quote Originally Posted by Kevin_From_NJ View Post
    Those are some of the biggest tires I have ever seen. They should fit on the lifted cutlass I just picked up.
    Ill need to get a rules clarification .
    But I believe that above a 22" rim your not allowed to call it a Cutlass anymore . It is referred to as a "donk". I really don't know why , since it is too tall for those extra large ba-donk-a-donks to line the back seat . If you did manage to crane them in there , the tires would rub and burn the paint and at that point it would be just another hooptie ...
    vnemous
    Gary no one wants to see you on a calendar
    Excellent point ....
    AZMIDLYF
    Mid Life , You don't miss a thing ...
    The Mrs . use to think I was crazy when I would tape rice paper to the TV and trace parts out , and scale it off of something else in the picture to get an exact size ... Now she helps ..
    I was released from my hand shake contract , so that I could build some Mercury stick-mids. All the jigs , fixtures , templates and stuff for doing 6 + 8 cylinder OMC's still belong to Gordon . Most importantly , I still get an invitation to the Christmas party ..
    There are a few reasons that the "trellis" looks tall . Compared to an OMC or 3.0 Merc , the 2.5 has a footprint that is only half as long , giving an allusion of being tall . With no diagonals in yet , you get the "pinstripe suit" thing happening .
    We are not going with the stock adapter plate which is aprox 3" tall . Instead we are using the "blender / coffee pot" as the bottom of the block . It's a really nice piece , built in Canada .
    Also , it will be run in a class that mandates a 15" mid section ... This one is proud by a sixteenth .
    I have some piece's under the tree's in front that tie into the swivel / tilt assembly that are a little different from the others I have made . These are spread out a bit and will bolt in place of a standard clamp bracket .
    The guys that are getting this one are already accomplished racers with a well set up boat and strong motor program . They have really been a pleasure to work with . Actually , my instructions were ... here's money , do your thing brother !
    Hard to beat that
    PS .. does that little tube look anything like the exhaust snout sticking back on a stock 15" can ...
    Maybe just a little ...
  4. Likes JrCRXHF liked this post
  5. #34
    Glad to see that style of contract still has merit today. Neat idea using standard clamp bracket set up. Snout shorter than the standard Aurora size of 12/13?
  6. #35
    Apr 2008
    georgia
    Kevin , "you da Man" thanks for the great pics as usual
  7. #36
    LOL You are correct Mikey!!!! BTW I mean't a Jasper calander.
    Gary
  8. Likes vnemous liked this post
  9. #37
    Sep 2007
    Awesome pics !! Thanks for sharing !
  10. #38
    I don't get the photo shop comment? I've spent some time in Charlie's shop and it looks just like that, in fact now there are many paintings reminiscent of a bad acid trip in the 60's
  11. #39
    Attached Thumbnails Attached Thumbnails 22450107_1887973494611282_709197339031930136_n.jpg
  12. #40
    May 2016
    Central FL
    That two tone blue STV is one sharp looking boat!!
  13. #41
    Quote Originally Posted by wicheckmate View Post
    The only thing E-Tec on it is the Air plenum..... But its a fine motor for sure.
    Blocks not Front half is and so is the 3.4L crank
  14. #42
    Mar 2010
    houston, tx
    Thank you Bill.
    You mean this one?
    I have the Nikon 70-200mmF4 and I just picked up a 1.4 Tele-converter which brings it out to 280mm. And of coarse I wish I had more at times but those big lenses are EXPENSIVE$$$ I am pretty happy with what I have. I blame all of this on Dan He had brought his camera years ago and he let me shoot with it and I was hooked. All I had before then was a little point/shoot camera.
    You guys are missed, hope to see you at the next one.
    Kevin
    I really like the nikon 300 f/4. Works well with the 1.4 tele as well. The older version can be had cheap in the used department now.
    Houston camera exchange has a good one for just under 400.00, I almost grabbed it since I miss mine so much. I’ve been using the 80-400 vr a lot and still miss the light fast 300/f4.
    They also have a version one 300 2.8 that’s rough looking on the outside from use but mechanically perfect. For 800ish
    I played with both of These and mounted to my body and tested. They are good to go. The 300 f/4 is clean.
    You can view view them online on their website and buy online too if you were interested.
    The 300 f/4 focuses ALOT faster than your 70-200 f/4 with a tele, heck it’s faster than my 70-200 2.8 vr with a tele.
    Anyway nice pics and thanks for posting im sad I missed it.
    Will be back for Catahoula and back to racing as soon as I have fixed all the Harvey damage on my house
  15. #43
    Feb 2010
    wisconsin
    Sooo like 20% lol
  16. #44
    What year did the E-Tec designation begin?
  17. #45
    Perhaps I didn't explain myself very well .
    There is a ton of weight in the stock clamp assembly . And of course I am doing one of my own . The OMC F1 is a tightly constructed unit with a fairly small bolt circle pattern.
    Mercury uses the standard bolt pattern and most transoms are drilled accordingly . Which gives me a little more room width wise to make the can not look so tall . Pictures also tend to distort things , well at least those shot from a phone . Kev , Greg and Freezzzee Jeff ~ not so much ..
    The handshake deal :
    I took a set of headers to my Porsche guys . They were a copy of some antique design that the car owner just had to have .
    The boss man asked how much he owed me ... I said , standard price will be fine .
    He said , I told you to keep track of your time , that I know these weren't going to be like the ones you can do in your sleep ... Normal price is fine .
    He handed me a check out of his top pocket for $100 dollars short of "double the standard price". I told him , I cant do that to you ... He said , look at it from my point of view ...
    If you don't make money , you cant pay your rent , light bill , phone bill so I can call you , sanding wheels , belts , grinding bits , stones , argon , tungsten , filler rod , lathe- mill bits - cutters and everything else it takes to keep the doors open . So you see , besides us being friends , it's in my best interest to see you succeed . With that , I took the check , shook his hand and thanked him ...
    On the way home , he texted me the specs on the next two sets he wanted built ...
    Vnemous :
    I've been accused of making the house smell like transmission fluid , machining oil , safety clean etc ...
    It's nice that I can return the favor ... geeezzz girls , the whole house smells like wet paint ...
    Some big art show , they got plans to rent a booth ...
    Best part is, in the mean time they don't try to micro manage what I'm doing .
    Even though , they don't spend money with me ...
    I took the high road and was their first sale ... kind~a matched our cars paint scheme ...
  18. Likes vnemous liked this post
  1. ODBA 2011 Jasper World Championships OFFICIAL RESULTS
    By Ray Leach in forum General Boating Discussion
    Last Post: 10-16-2011, 09:14 AM
  2. 2010 ODBA World Championships on DVD
    By Anxious1 in forum General Boating Discussion
    Last Post: 11-29-2010, 07:34 PM
  3. 2005 Odba World Championships
    By Rusrog in forum Racer's Hangout
    Last Post: 10-06-2005, 07:24 PM
  4. 2005 Odba World Championships
    By Rusrog in forum General Boating Discussion
    Last Post: 09-23-2005, 09:24 PM
