Results 1 to 12 of 12
Thread: 280 with 260 electronics issues
10-17-2017, 04:59 PM #1
So I made the switch to 260 electronics with plans of drag racing the boat. It’s a v-king with a 280. Before the switch I had the boat running 106 at 7500 rpm with a 32 coerced cleaver.
Now I’ve made the switch and things aren’t running so well. I think it must be the brucato ACU. Boat starts great, idles great but lower than it used to. Around 5-6k rpm it seems to vibrate, something it never did before, very annoying but if you power through it, it goes away above 6k. I feel like the motor has lost top end power or actually I know it has. I ran a Kanner 30 merc cleaver the other day and it only touched 7000 rpm. It was a much hotter day but I don’t care. Obviously a 280 on a v-king with a 14.5 x 30 merc cleaver should be running some higher rpms.
Also really want to figure figure out why it’s vibrating.
Havent had the time time to drive the boat much as it stays at my dads place and I’m far away but I really want to get this issue resolved. If the box is running too rich would it cause the vibrating? As well as a loss of top end power???
Any ideas will help. I’ll try to get a call in to brucato next summer when I can test the boat as well. Just looking for some tips.
carltonHydrostream V-king 2005 280
10-17-2017, 06:41 PM #2Member
- Oct 2015
- ont canada
- 30
- 45
check timing and box is probabaly rich
NICE PAIR liked this post
10-17-2017, 06:50 PM #36000 RPM
- Aug 2011
- ct
- 1,017
- 12
- 65
Brucato is probably very rich. The 280 electrics run very well, start nice and charge well. Your going to do a lot of tuning to get back where you were.
10-17-2017, 07:16 PM #4
Make sure map sensor fitting is clean also, can make it go stupid rich.
10-18-2017, 12:23 AM #5
Try a smaller pitch prop if rpm stays at 7000 the ignition may be your problem.
10-18-2017, 05:52 AM #66000 RPM
- Loudon Tn
- 1,430
- 7
- 59
Sorry to tell you (my two cents) you made a mistake going with 260 electronics etc. You would have been much better off just having 280 ECU limiter moved up. Been there done that
10-18-2017, 05:59 AM #7Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
how high will 280 inductive ignition run before it fades away?
10-18-2017, 04:02 PM #8
10-18-2017, 04:04 PM #9
10-22-2017, 02:16 AM #10
Timing is easy, so start there.
The next step is to see what you can learn from plug chops, i.e.
1. Go to starting position for WOT run
2. Change to a new set of plugs
3. Run at WOT
4. Switch off the ignition at WOT
5. Look at your plugs right there on the water, so you that know what was going on in the engine at WOT
Are all plugs looking too wet or dry? Are some looking different than others?
With that information, you can start figuring out which cylinders are affected, and whether it is fuel or spark-related.Markus' Performance Boating Links:
10-22-2017, 05:03 AM #11
Do u have any idea What fuel curve is in your acu? Tony’s base a6 curve is close but always on the rich side Straight from him. Did u go 56 or 39lbs system?
Nitrous is like a slut. u wanna hit it but you know there will be consequences.
10-22-2017, 05:15 PM #12
After you do a plug cut tow the boat in and read the piston tops. Ask Jay at JSRE.
Popey
Why put 260 electronics on a 280?
By RUDERIOT in forum Technical DiscussionReplies: 4Last Post: 09-06-2005, 08:21 AM -
2.4 electronics on a 2.5 ?????????
By northeastcat in forum Technical DiscussionReplies: 5Last Post: 07-18-2005, 09:02 PM -
2.4 electronics , help
By northeastcat in forum Technical DiscussionReplies: 2Last Post: 06-25-2005, 05:00 PM
