Results 1 to 5 of 5
Thread: Lower unit interchange
10-17-2017, 01:36 PM #1Junior Member
- Oct 2017
- AR
Will a sport master lower unit from an XS fit a Promax? Both 20”. Promax currently has a sport master that is damaged. Thanks I’m adva for any help!!
10-17-2017, 01:37 PM #2Junior Member
- Oct 2017
- AR
Both engines were/ are 300
10-17-2017, 03:16 PM #3
Yes however if the xs has a bass mid and the Promax has an offshore mid you will need 4 longer studs in the mid section to bolt up to the lower unit cause the mating surface is thicker on the sporty.
10-17-2017, 03:29 PM #4Junior Member
- Oct 2017
- AR
Both are off shore mids. Are the drive shafts the same? Same spline same diameter? Will it go right together in theory?
10-17-2017, 04:31 PM #5
Yes
By Wingnut0302 in forum Technical DiscussionReplies: 3Last Post: 06-12-2011, 09:19 PM -
OMC Tech: lower unit interchange ??
By rude power in forum Technical DiscussionReplies: 3Last Post: 06-08-2009, 09:10 PM -
By rude power in forum Technical DiscussionReplies: 8Last Post: 04-06-2009, 08:52 PM -
By indiana jack in forum Technical DiscussionReplies: 1Last Post: 07-11-2006, 10:29 PM -
By indiana jack in forum Technical DiscussionReplies: 1Last Post: 06-26-2006, 07:54 AM
