Results 1 to 12 of 12
Thread: Plugs for 300x
    Mar 2017
    central fl
    Plugs for 300x
    I saw on a previous thread where some are using the NGK BR8IX and NGK BR8HS for 3L motors. Is this a sub. for the 300x motors? I am using the Champion QL77PP now with a rough idle and low end. Any idea if the NGK would help?
    Thanks..
    New Smyrna Beach, FL.
    I have never been a fan of Champion plugs but the X motors have been quirky when I have run anything else in them.
    Seems like you have to check the gap on any plug you buy now. Had a 300xs i worked on that was running bad and discovered the gaps were all over the place. Owner had not checked them before installing himself. I set gaps properly, and it ran fine. jm2cts
    Mar 2011
    Carrollton VA
    Sorry, double post
    Go Time
    2003XS GS 225 Promax
    26 Regulator twin 250 EFI
    Mar 2011
    Carrollton VA
    The QL77PP have always run the best for us in the X motors. And we run them hard.
    Go Time
    Dec 2013
    georgia
    Quote Originally Posted by JPEROG View Post
    Jan 2007
    Quote Originally Posted by Go Time View Post
    Where do you gap them? Factory spec or something else?
    2001 Spectre 30 w/twin 300X
    2008 Velocity 390SS w/twin staggered 525efi - sold
    2003 Sonic 31SS w/twin 496HO - sold
    1988 Baja Sunsport 196 w/500HP SBC and 125 shot nitrous - sold
    Mar 2011
    Carrollton VA
    There was a service bulletin on them concerning plug gap. I dont have it in front of me, but I seem to remember it was increased to .040... someone will chime in if thats wrong.
    Go Time
    2001-03 APRIL 2001
    Printed in U.S.A. -
    2001, Mercury Marine
    Page 1 of 1
    No. 2001-03
    WARRANTY INFORMATION
    SERVICE INFORMATION
    Correct Spark Plug Gap for 300X Pro Max
    Models
    All 2001 Model Year 300X Pro Max Engines
    Situation
    The spark plug gap specification is incorrect on the emissions sticker attached to the engine
    and in the Operation, Maintenance and Warranty Manual. The incorrect gap is 0.035 in.
    (0.89 mm), which is too wide.
    Correction
    The correct spark plug gap for the 300 X Pro Max is 0.025 in. (0.64 mm). When checking
    or installing spark plugs, set the gap at 0.025 in. (0.64 mm)
  10. Likes PlumCrazy liked this post
  11. #10
    Mar 2017
    central fl
    Thanks, that is some good info..
  12. Likes PlumCrazy liked this post
    Nov 2009
    hardyville va
    Beware when gapping a PP. Easy to break off the platnum wafer.
  14. #12
    Jun 2004
    port st. lucie, fl
    Br8hs work fine, I wouldn't put champions in a lawn mower! If u run it hard for long periods run the br9hs, I usually gap them to .028-.030. u can use the br8hix, more expensive and an iridium plug.
  1. 300x spark plugs
    By Michael J Giesler in forum Technical Discussion
    Last Post: 06-30-2014, 07:27 AM
  2. 300X Plugs
    By Scott Tharpe in forum Technical Discussion
    Last Post: 08-19-2011, 11:43 AM
  3. 300X fouling plugs
    By swampster9 in forum Technical Discussion
    Last Post: 02-14-2008, 05:21 PM
  4. Spk Plugs In A 300x
    By jerry in forum Technical Discussion
    Last Post: 08-01-2006, 04:03 PM
  5. Plugs For A 300x
    By beer30 in forum Technical Discussion
    Last Post: 08-05-2004, 08:21 AM
