Results 1 to 6 of 6
10-16-2017, 10:34 PM #1Junior Member
- Nov 2004
- sacramento
- 12
Well where do i start 1996 Mercury 200 efi (OG304525)??????? MELT DOWN.
Hello All my belief is that i had a 1996 200 efi(this was on the lower unit as it attached to the boat OG304525), After the motor over heated i decided to rebuild the motor. i started to take the motor apart this is what i found head part number is(18488-C4) front half (969-9078-C5) block number (884-97-63C) can anyone tell what i have from the infomation I have provided?
thank you Walt
10-17-2017, 06:51 AM #2
You'll get a lot more info with pictures and maybe a serial number.
RockTeam Junk
10-17-2017, 08:36 AM #3
See if there is a serial number stamped in the block plug (on top of block) above the starboard cylinder bank.
Go Time
26 Regulator twin 250 EFI
10-17-2017, 02:02 PM #4Junior Member
- Nov 2004
- sacramento
- 12
just checked no numbers on that freeze plug
10-17-2017, 02:50 PM #55000 RPM
- Dec 2012
- tn
- 686
- 17
- 46
Do the sleeves have exhaust relief ports? 200s do not
175 and 150 do.
10-17-2017, 02:54 PM #65000 RPM
- Dec 2012
- tn
- 686
- 17
- 46
how about stamped letters on side of block above throttle lever- right along front and back half mate line? Look for something like CC, DD FF plus there should be a manufacture date
stamped in same area
Melt down
By flabum1017 in forum Technical DiscussionReplies: 11Last Post: 11-09-2012, 06:58 AM -
OMC Tech: 1996 175 fast strike will not start
By nitrohydro2000 in forum Technical DiscussionReplies: 6Last Post: 08-31-2012, 08:39 PM -
What caused this to melt?
By K-Dawg in forum Technical DiscussionReplies: 9Last Post: 01-03-2012, 07:28 AM -
Melt a 2.4 or not?
By Techno in forum Technical DiscussionReplies: 0Last Post: 04-09-2003, 06:34 PM -
Stop the melt down
By us1 in forum Technical DiscussionReplies: 2Last Post: 10-13-2001, 06:20 PM
