Results 1 to 6 of 6
    Nov 2004
    sacramento
    Well where do i start 1996 Mercury 200 efi (OG304525)??????? MELT DOWN.
    Hello All my belief is that i had a 1996 200 efi(this was on the lower unit as it attached to the boat OG304525), After the motor over heated i decided to rebuild the motor. i started to take the motor apart this is what i found head part number is(18488-C4) front half (969-9078-C5) block number (884-97-63C) can anyone tell what i have from the infomation I have provided?
    thank you Walt
    Pekin, IL
    You'll get a lot more info with pictures and maybe a serial number.
    Rock
    Team Junk
    Mar 2011
    Carrollton VA
    See if there is a serial number stamped in the block plug (on top of block) above the starboard cylinder bank.
    Go Time
    2003XS GS 225 Promax
    26 Regulator twin 250 EFI
    Nov 2004
    sacramento
    just checked no numbers on that freeze plug
    Dec 2012
    tn
    Do the sleeves have exhaust relief ports? 200s do not
    175 and 150 do.
    Dec 2012
    tn
    how about stamped letters on side of block above throttle lever- right along front and back half mate line? Look for something like CC, DD FF plus there should be a manufacture date
    stamped in same area
  1. Melt down
    By flabum1017 in forum Technical Discussion
    Last Post: 11-09-2012, 06:58 AM
  2. OMC Tech: 1996 175 fast strike will not start
    By nitrohydro2000 in forum Technical Discussion
    Last Post: 08-31-2012, 08:39 PM
  3. What caused this to melt?
    By K-Dawg in forum Technical Discussion
    Last Post: 01-03-2012, 07:28 AM
  4. Melt a 2.4 or not?
    By Techno in forum Technical Discussion
    Last Post: 04-09-2003, 06:34 PM
  5. Stop the melt down
    By us1 in forum Technical Discussion
    Last Post: 10-13-2001, 06:20 PM
