Page 4 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 46 to 60 of 159
  1. #46
    Sure, but the actual #s? Think they're on another thread. Are the 77 140 # the highest etc TR and EX?
  2. #47
    Jan 2010
    Venice, FL
    Well I ain't got exact specs FMP, but the ports on a 115/140 block are about the size of a quarter. Dime sized on a 85 - 90.
  3. #48
    I have them somewhere. I thought about 96 for ex, can't remember maybe higher. Someone get a wheel on one.
  4. #49
    Jun 2017
    fife scotland
    Quote Originally Posted by 71V153 View Post
    Look on top of of #2 cyinder. Just fwd of the head. Does it say 11 or 9?
    Tells ya everything ya need to know far as current port timing.
    This will throw you mine says D3Click image for larger version.
    Then it says 85 but with what looks like an 11Click image for larger version.
Name:	good clear 1.jpg
ID:	392530Click image for larger version.
    I love my Bikini
  5. #50
    Jun 2017
    fife scotland
    Once i opened up the exhaust cover i found the bolt holes for the exhaust stuffers Attachment 392532Attachment 392533Attachment 392534
    This is a flat back so why have the bolt holes ????
    It seems this was an one for all block but it does not have the bottom rib machined out
    Whats the chances of her having 140 ports ????
    I love my Bikini
  6. #51
    Put the crank , flywheel and one rod piston back in it and degree it, transfers and exhaust. Measure the port hole sizes. While you're at it measure piston height at tdc to deck, see how far down it is from the deck. Someone may give distance from deck or crank measurements to compare. Decking it will not change your duration.
    Then you know.
  7. #52
    Jun 2017
    fife scotland
ID:	392541Click image for larger version.
ID:	392542Click image for larger version.
ID:	392543This is what i found under my exhaust cover
    I love my Bikini
  8. #53
    Still assembled good. Dwell tdc to your timing marker and flywheel. Index the flywheel marking degrees around. If you take your time and care you'll get all the right numbers. If you have a degree wheel fix it to the top of the flywheel, 0* TDC. You're checking when the piston crown breaks light at the port roof in degrees from TDC. Get your numbers
  9. #54
    Jun 2017
    fife scotland
    Thanks FMP i will try and get that done tonight or tomz. I think the ports look pretty small so i guess it was just the bolt holes they left in.
    But it wont be a problem to try it and see for sure.
    Better still if i could see a 140 port and tell right away
    Andy
    I love my Bikini
  10. #55
    Jun 2017
    fife scotland
    OK i have pics of the ports and can see how much they have to be worked
    85hp Click image for larger version.
Name:	90hp intake ports.jpg
    140hp Click image for larger version.
Name:	140hp intake ports.jpg
    At least i know what is in front of me
    Andy
    I love my Bikini
  11. #56
    A bit of machining to do .... bigger ports maybe a couple degrees up. Chest and deck , high c heads. Not one 140 over your way to persuade into a sell. Good thing is you can move the ports where you want if needed.
  12. #57
    Those pics of the tranfers, you have a 140. Pics in the same room
  13. #58
    Aug 2009
    mpls,mn
    I just posted the #s your looking for on olboatmans thread oops but there they are.Take the bottom rib out,you have the small ports.All the v-4 blocks have the bosses for the stuffers when they sleeve them than they cut the ports for the hp rating. If you want to save some money don't put the stuffers in and you wont have to machine them either works better or its up to you if you do or not.
  14. Thanks spybot thanked for this post
    Likes spybot liked this post
  15. #59
    Aug 2009
    mpls,mn
    the pics of your intake ports are not a 115-140 they are 85-90 ports look at them there is a good 1/4 inch between them .
  16. #60
    Jun 2017
    fife scotland
    The pics were sent to me. But thanks to racervboat i now have everything i needed to know plus some great advice regarding the stuffers.
    Andy
    I love my Bikini
  1. AE-21 Rigging begins!
    By JUPITER PULSARE in forum Props, Setup, and Rigging
    Last Post: 09-05-2011, 05:27 PM
  2. The fun begins!!
    By ShorePounder in forum Other Motorsports
    Last Post: 10-06-2006, 12:00 PM
  3. The Fun Begins
    By Liqui-Fly in forum Fiberglass and Composites Discussion
    Last Post: 06-25-2003, 02:38 PM
  4. Woo hoo, now the fun begins!!
    By insptech in forum General Boating Discussion
    Last Post: 09-06-2002, 05:04 PM
