Results 31 to 45 of 159
Thread: 85hp V4 Mod begins
11-13-2017, 07:30 AM #31
11-16-2017, 08:09 AM #32
11-16-2017, 08:40 AM #33"12" Super Lite Tunnel (11') "88" 25 Yammy twin carb "BANANA SPLIT"
11-16-2017, 08:57 AM #34
Thanks Gary
Just trying to get all the info i need gathered up.
The port sizes are one of the most important but one of the last things i need (Info Wise)
Will post a few pics of the heads and intake later on.
Something strange been happening on the port side pots.
Maybe someone can tell me what has caused the difference.
11-18-2017, 08:34 PM #35
OK according to my guru if the 85 is the large bore (3.5") the ports should be simular to the 140s. Add the bubble back, hi comp heads, larger intake, reeds and carbs and ya should be close to a 140. You could square off the ports ( I usually do since it is open) and add a little timing. You will see an improvement!!! Don't forget most of the mph improvement will be in the setup and prop.
GaryLast edited by olboatman; 11-18-2017 at 08:39 PM. Reason: old age!
Mark75H liked this post
11-18-2017, 08:39 PM #36Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
And if is a small, find a large ? I was waiting for the numbers, just to see how it's timed for comparison.
11-18-2017, 09:00 PM #37
I understand Frank but Ken doesnt have them and I looked around but can't seem to find them. Maybe I should start a thread to ask?
Gary"12" Super Lite Tunnel (11') "88" 25 Yammy twin carb "BANANA SPLIT"
11-18-2017, 09:01 PM #38Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Just for kicks. I had the KR 15 #s somewhere or whatever someone made them.
11-19-2017, 05:26 PM #39
You have lost me on the "larger intake" Do you mean by smoothing out the bumps and casting marks ?
also when you say add a little timing Do you mean advance or retard the timing ?
Sorry if the above are dumb questions
Thanks again for the info, mine is the large bore model.
Hopefully get the intake and reed cages done this week, will post the pics of my progress.
I will start a new thread on the size of the ports once i can get a map done.
Andy
11-19-2017, 05:53 PM #40Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Search online Two Stroke Tuners Handbook, read it you'll like it.
Port timing, height of ports in degrees of crank rotation, duration open .
11-19-2017, 07:55 PM #41
Andy go to the thread I started (Port timing #s for an OMC 140) this morning and read what racervboat posted. I ment adding a couple Deg of timing and if I am correct the 140 front case has larger carb holes and flows better (someone correct if I am wrong Please). Notice that racervboat said run the stock tuner. He raced these motas for a few yrs and did very well...he built the mota I have for my Viper (a clone of his race motas) and his work is top notch!
11-19-2017, 08:30 PM #42
Think the V4 intake manifolds are purty much the same regardless of HP. Later ones were an inch taller and incorporated fuel recirc lines. Shift linkage was updated too.
11-19-2017, 08:44 PM #43
Look on top of of #2 cyinder. Just fwd of the head. Does it say 11 or 9?
Tells ya everything ya need to know far as current port timing.'71 Glastron V153 - Composite rebuild - Unceremoniously wrecked
11-19-2017, 09:07 PM #44Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Well, how much info can two #1s side by side tell us?
11-19-2017, 09:36 PM #45
That the block is ported to 115/140 specs?
AE-21 Rigging begins!
By JUPITER PULSARE in forum Props, Setup, and RiggingReplies: 162Last Post: 09-05-2011, 05:27 PM -
The fun begins!!
By ShorePounder in forum Other MotorsportsReplies: 2Last Post: 10-06-2006, 12:00 PM -
The Fun Begins
By Liqui-Fly in forum Fiberglass and Composites DiscussionReplies: 81Last Post: 06-25-2003, 02:38 PM -
Woo hoo, now the fun begins!!
By insptech in forum General Boating DiscussionReplies: 6Last Post: 09-06-2002, 05:04 PM
