Page 2 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 16 to 30 of 159
    Jan 2010
    Venice, FL
    Slop is one thing but .016+ clearance. Must sound like a bag of hammers. Could 10 up the rings and still be loose after a hone.
    Yeah but if you cut .016 in half it's .008. Max 'allowed' piston clearance according to OMC is .0075.
  2. #17
    Phew,lol
  3. #18
    Jan 2010
    Venice, FL
    Actually I was being serious. All has to do with bores and diameters I reckon. Think .004 is tight as they recommend for a oversize piston?
  4. #19
    I'd bolt the heads back on and go fishing.
  5. Likes 71V153 liked this post
  6. #20
    This is the motor that's getting worked to 140
  7. #21
    ....and you can't measure clearances with a feeler gauge, besides ring gap.
  8. #22
    May 2014
    Livingston, Louisiana
    And for sure not measured at the crown of the piston.
  9. #23
    Once the ports are brought to 140 specs you need to be right on with piston clearence and ring gap......as they grab rings when sloppy....been there!
    JMO (just my Observation)
    Gary
  10. Likes spybot liked this post
  11. #24
    Jun 2017
    fife scotland
    Thanks for the info guys.
    Is the markings normal for the V4 engine ?
    I love my Bikini
  12. #25
    May 2014
    Pistons are shaped with a taper with top being much smaller than bottom. So it will show much more clearance at top than bottom in skirt area. Just wanted to clarify my post so my short answer didn't appear to be critical or sound like a jerk. After I read it, saw it could have been taken the wrong way. So measuring at top of piston doesn't really tell ya much, piston would need to be removed and measured near bottom to get an accurate clearance reading.
  13. Likes spybot liked this post
  14. #26
    Good point, note the extra top clearance is to soak the heat. Measure forged vs cast and note the difference. Marks in the bore will be gone when you bore it.
  15. #27
    Gary
    Gary, do you know the stock timing* numbers for the 140 in and out?
  16. #28
    No I don't Frank ..... Maybe racervboat will chime in as I'm sure he has them and if he doesn't soon I will contact him.
    Gary
  17. Thanks spybot thanked for this post
  18. #29
    I thought to ask, I have an idea but more importantly the build here would probably need to know.
  19. Thanks spybot thanked for this post
  20. #30
    Dec 2001
    Poor mans way. Put piston in bore crown first and check top of bore to bottom of piston with feeler gage.
  21. Likes 71V153 liked this post
  1. AE-21 Rigging begins!
    By JUPITER PULSARE in forum Props, Setup, and Rigging
    Last Post: 09-05-2011, 05:27 PM
  2. The fun begins!!
    By ShorePounder in forum Other Motorsports
    Last Post: 10-06-2006, 12:00 PM
  3. The Fun Begins
    By Liqui-Fly in forum Fiberglass and Composites Discussion
    Last Post: 06-25-2003, 02:38 PM
  4. Woo hoo, now the fun begins!!
    By insptech in forum General Boating Discussion
    Last Post: 09-06-2002, 05:04 PM
