Page 11 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11
Results 151 to 159 of 159
  1. #151
    Jun 2017
    fife scotland
    This thread has sort of encompassed all of my winter projects but to bring this back on track.
    My 85 to 140 mod is in the beginning but i have put a dead line on it.
    I must have the engine stripped and rebuilt by the 1st of Feb.
    Here is a wee recap on what i want to do plus a few extra bits of info.
    I want to turn my 1980 Johnson 85 into a 140 but a decent 140.
    I know i have machining to get done (bottom rib removed, ports widened to 140 and block milled for filler plates) I also need two cylinders to be re bored to 2nd over size.
    Now i have this work to be done on a budget. Its a real tight budget.
    I have all the parts to make the mod, High comp heads 1 5/16th carbs, intake and exhaust stuffers.
    I have purchased a job lot of wise pistons so will be using these, Santa brought me a set of Carson reeds.
    I have a 21" prop from a friend,
    The motor i want to build is for play more than race so 6500rpm will be my goal.
    Already port flowed the intake and the carbs. I will port match/flow every part of the build. The rods and pistons will be balanced.
    The ignition system is CD2 i cant afford to up grade to CD4
    What else can i do to help the engine stay strong at 6500rpm ?
    The boat is a sidewinder copy at 16ft and 660lbs
    Guys i dont have a shed load of money to dump im to this, in fact i had to save all year for the parts i have.
    Plus i stay in Bonnie Scotland so there are not many spares to be had.
    Any and all help welcome
    Cheers Andy
    I love my Bikini
  2. #152
    Where's the floor of the ex ports in reference to the piston crown at BDC on these V4s?
  3. #153
    Jun 2017
    fife scotland
    This thread is now closed.
    I am selling my 85hp so anyone in the UK looking for a good rebuilt V4 85hp let me know.
    I will start a new thread as i have got my hands on a 1979 115hp
    This should be turned into a 140 very easily.
    Thanks for all the input and be sure to follow my new thread" Modding a Johnson V4 115hp into a 140
    Cheers Andy
    I love my Bikini
  4. #154
    Aug 2009
    mpls,mn
    Put the bubble back exhaust on the 115 and the tighter heads and you have a 140hp.
  5. #155
    Jun 2017
    fife scotland
    Quote Originally Posted by racervboat View Post
    Bonus it has a bubble
    I have the stuffers for the reeds and a set of 1 5/16th carbs to go on plus the H/C heads.
    I will do a bit of port flowing ? Is that the correct wording i mean its only smoothing the air flow from the carbs till the hit the reeds.
    It has a choke but i will be changing that to the primer system. Shooting the fuel mixture direct into the bypass cover.
    It will take a wee bit of work but think i can get to 140 in no time.
    I get the engine on Thursday the 1st ironically the date i wanted the 85 project completed.
    When the heads are off i will strip it down tackle squaring the ports and get it honed as i have a new set of wiseco pistons sitting .
    Think i will need to pick your brain regarding jetting plus a lot of other things.
    Maybe get it done a 2 weeks ????
    Any ideas or things i should not do ?????
    Andy
    I love my Bikini
  6. #156
    Quote Originally Posted by spybot View Post
    Andy
    Yes Andy I have an idea of what you should do....Ship it to racervboat!!! lol Just kiddin as I'm sure Ken will steer you in the correct direction.
    Gary
  7. #157
    Jun 2017
    fife scotland
    If i could i would in a heartbeat.
    I will have get my advice long distance
    Andy
    I love my Bikini
  8. #158
    Aug 2009
    mpls,mn
    the 115 is basically a 140,its got the bubble back and 140 ports already and should have 1 5/16 th carbs if it does not have the high comp heads swap them out and you have a 140 .
  9. #159
    friend of mine is going to be making the tuners for these, the proper ones as fitted to the 1977 140 ( the real 140 crossflow).
    dont know a price for them yet though.
  1. AE-21 Rigging begins!
    By JUPITER PULSARE in forum Props, Setup, and Rigging
    Last Post: 09-05-2011, 05:27 PM
  2. The fun begins!!
    By ShorePounder in forum Other Motorsports
    Last Post: 10-06-2006, 12:00 PM
  3. The Fun Begins
    By Liqui-Fly in forum Fiberglass and Composites Discussion
    Last Post: 06-25-2003, 02:38 PM
  4. Woo hoo, now the fun begins!!
    By insptech in forum General Boating Discussion
    Last Post: 09-06-2002, 05:04 PM
