Results 1 to 9 of 9
    Jan 2010
    north carolina
    95 OMC 150, max timing, 175 throttle bodies n carbs. ? PLEASE...ANYONE?
    It is on a light boat. stock, with ccm reeds. 93 oct,gas...can I go to 22 degrees? No lugging here either idling or WOT... worked 23-24p 4 blade renegade, 6000@67... I pull the plugs and inspect after each outing. Should I be happy with what I am getting,and leave it at 20? I am checking it at 5300 going across the lake. Would 175 throttle bodies reeds and carbs give me anything? ANY TIPS WOULD BE APPRECIATED!
    Jan 2010
    north carolina
    Reguarding timing
    I think that you are doing pretty good with what you have. You can try advancing it a little, but keep an eye on the piston tops. If you don't pick up any rpm's just put it back to 20. You might want to try and find a set of throttle bodies and carbs.from a 175. Seeing how you are on a tight budget,and can't afford a re-power.
    Jan 2010
    north carolina
    Thanks for the reply. I have ported and rebuilt a few v-6 cross flows. There are some good looper mod threads on here. just waiting for this one to burn a piston or eat a ring so I can go spybot on it..lol. Wish I could get just a little help here with the timing and 175 parts Questions. Did I mention I'm schizophrenic?
    Aug 2009
    mpls,mn
    you just replied to your own thread x2 WTF
    Jan 2010
    north carolina
    There i got a reply!! Hahaha.... Just hoping someone would chime in on my questions...
    Jan 2010
    north carolina
    Racervboat, It's called a sense of humor, something you don't have. WTF to you!!
    Mar 2004
    Brooklyn Park, MN
    I though it was a glitch. I didnt get it either but good to know it was not an issue with the site.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
    May 2014
    Livingston, Louisiana
    Man, sorry no one has answered you. I wish I could tell ya, but I'm not familiar with the omc and wouldn't won't to cause ya to blow your junk up ! Hopefully one of the guys like racer will chime in and give ya some sound advice. Good luck to ya!
  9. Thanks oldschoolnc thanked for this post
    Likes oldschoolnc liked this post
  10. #9
    Jan 2010
    north carolina
    Thanks FORBESAUTO.. I just got frustrated with so many knowledgeable people on this site, I thought I would have gotten a quick answer. I lightened it up 60lbs. set timing at 22btdc and ran 69@ 6100, 7% slip. plugs and pistons look good. I'm proud of those #'s... Still would like to know if 175 throttle bodies reeds and carbs. would give me anything?
    Sorry racervboatI was having a bad day.....
  1. Ignition timing
    By RNM018 in forum Technical Discussion
    Last Post: 09-12-2012, 10:15 PM
  2. Mercury Tech: SST 120 Ignition Timing
    By Aussy Racer in forum Technical Discussion
    Last Post: 10-15-2008, 04:07 AM
  3. Ignition Timing
    By scott mann in forum Technical Discussion
    Last Post: 09-24-2005, 08:59 AM
  4. Johnson V4 ignition timing
    By chris_lacey in forum Technical Discussion
    Last Post: 09-11-2002, 06:27 AM
  5. OMC Ignition Timing
    By DSP1 in forum Technical Discussion
    Last Post: 12-20-2001, 01:54 AM
