Results 1 to 9 of 9
Thread: 95 OMC 150, max ignition timing?
10-14-2017, 03:38 PM #1
95 OMC 150, max timing, 175 throttle bodies n carbs. ? PLEASE...ANYONE?
It is on a light boat. stock, with ccm reeds. 93 oct,gas...can I go to 22 degrees? No lugging here either idling or WOT... worked 23-24p 4 blade renegade, 6000@67... I pull the plugs and inspect after each outing. Should I be happy with what I am getting,and leave it at 20? I am checking it at 5300 going across the lake. Would 175 throttle bodies reeds and carbs give me anything? ANY TIPS WOULD BE APPRECIATED!
10-16-2017, 06:53 PM #2
Reguarding timing
I think that you are doing pretty good with what you have. You can try advancing it a little, but keep an eye on the piston tops. If you don't pick up any rpm's just put it back to 20. You might want to try and find a set of throttle bodies and carbs.from a 175. Seeing how you are on a tight budget,and can't afford a re-power.
10-16-2017, 07:11 PM #3
Thanks for the reply. I have ported and rebuilt a few v-6 cross flows. There are some good looper mod threads on here. just waiting for this one to burn a piston or eat a ring so I can go spybot on it..lol. Wish I could get just a little help here with the timing and 175 parts Questions. Did I mention I'm schizophrenic?
10-16-2017, 11:40 PM #4
you just replied to your own thread x2 WTF
10-17-2017, 09:30 AM #5
There i got a reply!! Hahaha.... Just hoping someone would chime in on my questions...
10-18-2017, 12:41 PM #6
Racervboat, It's called a sense of humor, something you don't have. WTF to you!!
10-18-2017, 03:49 PM #7
I though it was a glitch. I didnt get it either but good to know it was not an issue with the site.
1973 Viper - sold
1978 Viking - sold
1995 XB02
10-18-2017, 09:28 PM #8
Man, sorry no one has answered you. I wish I could tell ya, but I'm not familiar with the omc and wouldn't won't to cause ya to blow your junk up ! Hopefully one of the guys like racer will chime in and give ya some sound advice. Good luck to ya!
oldschoolnc thanked for this postoldschoolnc liked this post
10-19-2017, 07:55 PM #9
Thanks FORBESAUTO.. I just got frustrated with so many knowledgeable people on this site, I thought I would have gotten a quick answer. I lightened it up 60lbs. set timing at 22btdc and ran 69@ 6100, 7% slip. plugs and pistons look good. I'm proud of those #'s... Still would like to know if 175 throttle bodies reeds and carbs. would give me anything?
Sorry racervboatI was having a bad day.....
Ignition timing
By RNM018 in forum Technical DiscussionReplies: 3Last Post: 09-12-2012, 10:15 PM -
Mercury Tech: SST 120 Ignition Timing
By Aussy Racer in forum Technical DiscussionReplies: 4Last Post: 10-15-2008, 04:07 AM -
Ignition Timing
By scott mann in forum Technical DiscussionReplies: 1Last Post: 09-24-2005, 08:59 AM -
Johnson V4 ignition timing
By chris_lacey in forum Technical DiscussionReplies: 5Last Post: 09-11-2002, 06:27 AM -
OMC Ignition Timing
By DSP1 in forum Technical DiscussionReplies: 1Last Post: 12-20-2001, 01:54 AM
