Results 1 to 12 of 12
    May 2005
    Louisiana
    etec 150 hp injector coeff numbers
    Can anyone help me decipher these injector numbers , particularly injector number 1
    coeff a , b , look off ? I know someone replaced this injector from another engine and am not sure if they had the dat file for the injector ? Is the injector addressable ? Thanks Davepnola
    Is there still a tag on the injector lead?
    May 2005
    Louisiana
    Yes ... I am thinking they did not program this used injector to the emm
    That has to be downloaded from brp than loaded to emm
    May 2005
    Louisiana
    Can u email file please , to globalauto@yahoo.com thanks
    May 2005
    Louisiana
    Have a link or dealer only ?
    Dealer and you have to have software that will talk to your emm I believe.
    Dec 2006
    You need to use EVdiagnostics and BossWeb to complete your injector programming.. Dealer only.
    May 2005
    Louisiana
    I have the ev diagnostics .... tell me if I am wrong but looking at the coeff numbers can u decipher that person that installed the used injector did not write the programming to the emm for injector number 1 ?
    Jul 2007
    Bay City, Texas
    your injector sn and the one on the engine report don't match. also you cant download the injector co efficient from the net on that injector. It has to have a check sum number to be able to down load it from the net.
    You reap what you sow, corny but true.
    May 2005
    Louisiana
    Ok I see that ... explain how the injector is addressable ?
    Is there rom chip in each injector with a gate to only allow emm to address each specific injector ?
  12. #12
    Jul 2007
    Bay City, Texas
    The injectors are controlled by the emm. The coefficient tells the emm how the injector flows. That is why the emm has to be updated when an injector is replaced. All new injectors have a sn and a checksum number on the tags, those can be downloaded from dealerport. The old injectors came with a floppy disc with the coefficients on it.
  1. Opti injector open fault. Injector/cylinder fine
    By RSWORDS in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 11-03-2017, 11:01 AM
  2. Etec 250 injector problem in Stuart Florida HELP
    By aboatersplace in forum General Boating Discussion
    Last Post: 04-24-2017, 06:33 PM
  3. Dirty Etec injector cleaning
    By wingtime in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 12-07-2015, 03:18 PM
  4. Leaking Fuel Injector hose from rail. Need to replace injector?
    By nburgart in forum Technical Discussion
    Last Post: 08-26-2014, 12:57 AM
  5. Replies: 7
    Last Post: 03-29-2011, 06:46 AM
