Results 1 to 5 of 5
10-09-2017, 04:14 PM #1Screaming And Flying!
- 14,700
- 380
- 1280
- 5599
- 10930
225 opti fuel rail diaphragms replacement procedure.
Got a fuel pressure diaphragm leaking (?) and causing fast idle issues on my opti. Was planning on replacing all the rubbers on the fuel rail at once for max reliability. This is an 2010 motor with 800 hrs. I get how to do the replacement of the parts I believe, but do I need to pop out the welsh plugs and change the pressure adj screws behind them. Or can I just replace the rubbers and it will be good to go pressure wise?
10-09-2017, 06:57 PM #2
The air pressure regulator has a small o ring, a diaphragm and an 80 lb spring. Merc sells a tool but a squeeze clamp works well. Put clamp on, take 4 allen screws out and slowly release spring. Tracker valve is similar to the air regulator but no spring.
10-17-2017, 07:30 AM #3Screaming And Flying!
- 14,700
- 380
- 1280
- 5599
- 10930
Just as a follow up on this. I replaced all three of the diaphragms and both O rings on the fuel rails and didn't touch the adjustment screws. It runs like new. The fuel press reg had a cracked dia. and was causing the motors hi idle condition. It was an easy fix. But not a cheap one since I replaced it all at once.
10-17-2017, 09:58 AM #45000 RPM
- Dec 2013
- georgia
- 550
- 31
- 24
- 57
- 65
Happy to hear you got problem fixed.
10-17-2017, 10:15 AM #5Screaming And Flying!
- 14,700
- 380
- 1280
- 5599
- 10930
Thanks! That makes two of us. Hit the key to start and it would red line if you let it. Scared the heck outta me.....All better now. Luckily I have a great merc dealer who cut me a break on the parts. The 3 diaphragms were 195 ea list....YIKES! I used mr demeanors trick on the air pressure regulator (80 psi spring) with the longer bolts to assemble, Made it easy. Did it all on the motor too. So a shout out of thanks to him too....
Hydrostream rub rail replacement
By Quinten in forum General Boating DiscussionReplies: 35Last Post: 07-13-2017, 08:41 PM -
OPTI FUEL RAIL adjustment
By wt3550 in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 6Last Post: 07-26-2016, 11:14 AM -
Rub rail replacement
By buffalo in forum General Boating DiscussionReplies: 3Last Post: 03-01-2015, 05:37 AM -
Optimax fuel and air pressurs diaphragms
By Bullet89 in forum Technical DiscussionReplies: 14Last Post: 02-22-2015, 11:24 AM -
STV rub rail replacement
By stvhelm in forum General Boating DiscussionReplies: 4Last Post: 03-25-2005, 10:40 PM
