Results 1 to 4 of 4
    ST.PETE FL.
    5 Thread(s)
    Late 90s left hand V6 GEAR CASE 20 INCH
    inleft hand2:1 gear case the unit has no reverse I don't know what happened it worked great forever and I went to put it in reverse and just wouldn't go could be a very easy fix also have a left-hand 19 pitch prop for stainless.mirage prop make a reasonable offer on everything and yours
    727 686 0900
    SEEBOLD CHAMPBOAT MERCURY S3000
    Sep 2002
    north port fl
    how much 4 the pool pump?
    Dec 2001
    If it is a locker case the shift pin cuda broke.reverse being F in a stock cases. In forward the shift dog gets pushed back. In reverse the shift dog gets pulled to the gear if the pin is broke it will not happen.
    Dec 2001
    locker case
    two kinds of lockers....the early ones only had lh gears. they were the best as no parts to fail. The newer shift one will break. The new merc non ratcit cases will break the shift pin.If not that the rear clip thah holds the gear/shaft in place gets gone and all **** come to a mess.SHTF.... Just what I have seen.
  1. Mercury 2 hole right hand cle gear case 20 inch
    By superboattwin250 in forum Lower Units
    Last Post: 12-01-2015, 07:13 PM
  2. left hand gear case and right hand the same?
    By Quinten in forum Technical Discussion
    Last Post: 06-27-2015, 09:57 AM
  3. Replies: 5
    Last Post: 08-26-2014, 10:14 PM
