Results 1 to 14 of 14
    Jul 2016
    Lincoln CA
    V-200 200hp 1986 2.4L - Freshing up kit and questions
    Hello SF Guys,
    I wanted to know of a good source for a refreshing up kit for this motor. All new bearings, seals, rings? Also would you advise new pistons? If so what is the benefit.... I also have a question about Bridgeport 2.4L heads. What if any improvement would I get from single piece heads? Good source for new reeds? Motor runs fine now, starts easy, runs great on the top end, but idol is rough and it loads up when I idol too long (premix motor) I assume new reeds will help a lot to fix this issue. after a rebuild, i will be pulling it off the current clamshell mid and putting it on a 2.0l 96 150hp mid section because the current steering pin is (yoke's) are shot and it is sloppy! Any advise is appreciated!
    May 2014
    Livingston, Louisiana
    Pro-Marine is a good source for engine parts. Chris Carson (CCMS) for the reeds. Need to check piston-bore clearance and check cylinder roundness and squarness from top to bottom 1st, may find will need to bore anyway requiring new pistons. If doesn't need to be bored and motor hadnt been ran hot prob could reuse pistons. The danger of reusing, especially if it had been ran hot is ring locator pins may come loose and cause major cylinder damage. But shy of top pinning them it's a chance no matter what even with new ones. Jmo
    Baton Rouge, La
    Like Forbes said , chrome motors that were run hot tend to have out of round cylinders.
    What carbs you running ? Usually you can lean the idle circuit of the wh carbs to fix that problem, increase idle air.
    Check the exhaust opening in the adapter plate to make sure its the same size. Smaller will hurt performance. You can shave heads for increased compression. Mike
    Cheaters never Win !!!
    Jul 2016
    Lincoln CA
    Quote Originally Posted by tunnelmike View Post
    If its a chrome bore (which it should be) can that block be bored like normal? When you refer to Chrome does that mean it has a Nic coated cylinder wall?
    Jul 2016
    Lincoln CA
    Also that site Pro-Marine has no pistons or rings for a 2.4L 200HP
    May 2014
    No can't bore, I had my head up my hynee wasn't thinking it's prob a chrome bore
    May 2014
    When I get away from the shop, ill dig around for ya and see what I can find for parts for the chrome bores
    May 2014
    1868 part number for standard rings on chrome bore motor. 2100p is std piston kit port side, 2100s is starboard kit, both pro pistons. The pro v part numbers are 2100pv and 2100 sv. All part numbers are from pro marine and their pistons. I prefer the pro v piston, but both are very good products.
    Baton Rouge, La
    My '86 was chrome so I assumed that one is too. Chrome was what they used before nikasil. I like them. Chrome and steel sleeves use different rings. Mike.
    Jul 2016
    Lincoln CA
    Can you Re Chrome if they are out of Round and require boring?
    Mar 2010
    houston, tx
    Quote Originally Posted by lcfishing13 View Post
    Us chrome will not re-chrome a motor anymore they will redo a 2.4 with nic instead however.
  12. #12
    Jul 2016
    Lincoln CA
    Quote Originally Posted by 90 5.0 View Post
    I dont have anyone local that does it. Not sure its cost effective on this motor to send the block off long distances
  13. #13
    Mar 2010
    houston, tx
    Us chrome is pretty much your only option I beleive but it’s irrelevant as most people are conferenced. For a standard 2.4 200 that needs multiple cylinders fixed it’s not cost prohibitive. Some people will put a steel sleeve in one hole to fix one but most people these days would just throw away a 2.4 200 with cylinder problems and throw a 2.5 drop on in instead.
    Better motor easier fixability more power etc etc etc.
    most people i know wouldn’t even consider a Bridgeport worth fixing much less a 2.4 200.
    Unless you just love 2.4’s most would just get a 2.5. They can be found very reasonable and there is more “fixability “ in the future, you can bore bad cylinders etc
  14. #14
    Jul 2016
    Lincoln CA
    I have not been able to find a 2.5L that has very much history ava with it.
  1. Mercury 200HP 2.4 1986 Laser II Prop ?
    By Steve200 in forum Props, Setup, and Rigging
    Last Post: 06-06-2020, 12:03 AM
  2. 1986? Mercury 200HP 2.4 Litre 20" For Sale
    By mragu in forum Outboard Engines
    Last Post: 11-15-2015, 02:50 AM
  3. Mercury Tech: 1986 2.4 200hp. Clunking in forward.
    By 86Eagle in forum Technical Discussion
    Last Post: 07-24-2014, 06:45 PM
  4. 1986 Mariner 200hp reduced rpm
    By ufish2 in forum Technical Discussion
    Last Post: 09-24-2013, 03:38 PM
