Results 1 to 8 of 8
    Oct 2013
    mississippi
    23ft SANGER ALLEY CAT TUNNEL HULL PICKLE FORK CATAMARAN 245hp DRAG MERCURY'S $12,000.
    I HAVE A GOOD SHAPE 23ft BY 8ft WIDE OFFSHORE SANGER ALLEY CAT. HAS 245hp CARBURETED DRAG MERCURY'S . THE RIGHT HAND MOTOR HAS A BAD PISTON, HAS A GOOD CLE RIGHT HAND LOWER UNIT . THE LEFT MOTOR IS MISSING THE POWERHEAD AND THE LOWER UNIT. THE BOAT HAS VERY NICE OFFSHORE STEERING. THE HULL IS A 1984 MODEL. INTERIOR HAS BEEN REMOVED BUT HAS BRAND NEW SEAT FRAMES, CUSTOM MADE FOR THE BOAT. WILL SEAT 5. JUST NEEDS TO BE COVERED. BOAT PAINT JOB IS STILL VERY NICE. IT WILL NOT TAKE ALOT OF WORK TO GET THIS BOAT BACK ON THE WATER ! IT WAS OVER 100mph WHEN IT WAS RUNNING. ALSO HAS TWIN HYDRAULIC JACKING PLATES. THIS BOAT IS GREAT FOR OFF SHORE USE. CAN RUN 80mph WITH NO PROBLEM ACROSS 3ft SEA'S . VERY FAST AND SAFE BOAT ! THIS ALSO INCLUDES THE TRAILER. 228-522-1600 OR 228-218-3080 CALL OR TEXT TO THE 228-218-3080 NUMBER. CALLS ONLY ON 228-522-1600 ASKING $12,000.00
    *SORRY FOR THE 8ft SEA'S TYPO* THIS BOAT HAS OFFSHORE STAINLESS STEEL STEERING WITH WING PLATES . TWO BOB'S HYDRAULIC JACKING PLATES . SINGLE RAM. DRAG MID SECTIONS. COMPLETE 245 DRAG MOTOR. CLE GEAR CASE. TWO DRAG COWLS WITH LOWER PANS. BEFORE TALKING ABOUT WHAT THIS IS WORTH, CHECK THE PRICES ON THOSE ITEMS ALONE. YOU CANT BUY THE USED STEERING FOR $2000.00 HOPE THIS MAKES YOU BETTER UNDERSTAND . ALSO HAS DUAL CONTROLS WITH CABLES THAT FUNCTION , MERCURY WIRING HARNESS'S. DOUBLE HOT FOOT THAT FUNCTIONS ! GAS TANKS ARE GOOD. THIS IS FAR FROM JUST A HULL.
ID:	388586   Click image for larger version.
ID:	388587   Click image for larger version.
ID:	388588   Click image for larger version.
ID:	388589   Click image for larger version.
ID:	388591   Click image for larger version.
ID:	388592   Click image for larger version.
ID:	388593   Click image for larger version.
ID:	388594   Click image for larger version.
    Jun 2001
    Punta Gorda, Florida
    I just went out back and hacked my Eliminator to pieces with a chainsaw being as it is totally incapable of traversing 8ft seas at any speed let alone 80mph!
  3. Likes Speed Jr., NICE PAIR liked this post
    Aug 2004
    nj
    Thought 80MPH in 8' Seas was hilarious.....��
    Liberator Doc
    Aug 2006
    virginia
    I just opened the plugs on the american offshore and let her go down also....then realized too late that its possible...if inbetween the swells
  6. Likes kragar liked this post
    Jun 2011
    Norcal
    Your caps lock is on.......
    ST.PETE FL.
    5 Thread(s)
    what a disaster. boats worth about 2 grand....what are 245 carb drags???LOL. just set that thing on fire and be done with it
    SEEBOLD CHAMPBOAT MERCURY S3000
    New Smyrna Beach, FL.
    Quote Originally Posted by PARKER RABE View Post
    I have to agree that he is a little optimistic on his pricing but its not a fire starter either. These were cool boats to see running around back in day (Charlie Watson had one on Gull Lake where I was raised) and he was a night runner. I can remember hearing him coming from miles away as a kid at night. My bedroom was about 50 feet from the shoreline. The same guy had a GS1100E with a 4 into 1 (large baffle) Kerker on it that used to make a good 1 A.M. alarm clock for the lake residents. There are just some sounds that you will never forget...
    Jan 2009
    Algonac Michigan
    $2000 sounds about right.
    "don't want no mates, there's too many captains on this island."
  1. 12' mini Eliminator pickle fork tunnel hull?????
    By Lakelife in forum Props, Setup, and Rigging
    Last Post: 10-29-2016, 12:54 PM
  2. Replies: 24
    Last Post: 09-30-2014, 09:27 PM
  3. Mini eliminator Pickle fork / Tunnel hull???
    By Swra311 in forum Technical Discussion
    Last Post: 04-16-2009, 11:06 PM
  4. Cat,Tunnel hull,Pickle fork, Hull Manufactures?
    By opmope in forum General Boating Discussion
    Last Post: 05-12-2008, 08:28 AM
