Results 1 to 8 of 8
10-03-2017, 08:17 AM #15000 RPM
- May 2008
- Walker, LA via H Katrina
- 194
Merc 1998 200hp reads replaced where are chipped peices?
Installed new CCMS reeds. But one reed had 1/4 missing. Three others had a very little chip missing. Where could the chips be? Removing head and blowing air is the only thoughs I have. Help!
10-03-2017, 07:05 PM #2Member
- Dec 2006
- Central Wisconsin
- 81
- 7
If ur really lucky the motor blew them out the exhaust....but theres only 1 way to know for sure
10-03-2017, 08:21 PM #35000 RPM
- May 2008
- 194
10-03-2017, 10:12 PM #4Member
- Dec 2006
- Central Wisconsin
- 81
- 7
If it were mine id split it....my friends xr6 did the same thing and he put new reeds in it and ran it. So far so good.....your call
10-03-2017, 10:19 PM #5
If it was trapped between the piston and cylinder wall youd know it by now.
10-04-2017, 05:01 AM #65000 RPM
- May 2008
- 194
10-04-2017, 07:00 AM #7Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,272
- 215
- 30
- 585
Small parts usually blow through with little or no damage,sometimes a little peppering on the piston\head,you can clean that up by removing the head,after you find it with a probe light.A bigger piece caught between the piston and cylinder wall usually results in noticable compression loss...Chris
10-04-2017, 07:15 AM #85000 RPM
- May 2008
- 194
Thanks Chris. I put a plastic drum under the lower unit and filled with water and vinegar 3:1. Ran motor to flush my new/used salt water fishing motor. Found shinny chrome looking specs or peppering in bottom of the plastice drum. Just a small amount. Looks like gold dust but chrome lookiing. Will re-check compression. Thanks again!
Merc 1998 200hp carb intake
By luckybuff in forum Technical DiscussionReplies: 1Last Post: 08-24-2017, 09:36 PM -
1998 Boston Whaler Ventura 20' Dual Console/200HP Merc EFI/Gal Trailer
By mragu in forum Hulls up to 20'Replies: 4Last Post: 11-25-2014, 10:57 PM -
Chipped Prop Repair ?
By DEYS in forum Props, Setup, and RiggingReplies: 2Last Post: 04-27-2012, 09:29 PM -
Mercury Tech: 1998 200hp Merc EFI hookup
By gerrysnell in forum Technical DiscussionReplies: 2Last Post: 07-30-2010, 01:04 PM
