Results 1 to 8 of 8
Thread: constant alarm 08 300xs
09-29-2017, 07:51 AM #1Member
- Nov 2013
- Wakefield, NH
- 79
hey guys, need a little help. once in a while, although more frequently lately, constant alarm when running wide open. when i back off it goes away, sometimes takes 10-20 secs. water pressure is great 15 lbs, temp is good 150, right about 6500 rpms, rev limit is 6850, any ideas?
09-29-2017, 09:14 AM #2
09-29-2017, 09:17 AM #3Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,640
- 606
- 920
- 1698
- 7137
- 3 Post(s)
Are you reading pressure from a gauge or smartcraft "which tells you what the computer is seeing"? its that or you are on the limiter.
09-29-2017, 11:22 AM #4
rev limit is 5800 on 25 inch 300xs. 6400 on 20 inch 300xs. if you are at 6500 that is reason for alarm. it should go into safe mode shortly after warning alarm. when it does it will not rev over 2500 until you shut it off and restart it.
09-29-2017, 04:53 PM #5
Your smart craft is reading 150 water temp or a analog gauge is? If its your smartcraft thats to hot.
09-30-2017, 05:34 AM #6Member
- Nov 2013
- Wakefield, NH
- 79
NICE PAIR liked this post
09-30-2017, 05:39 AM #7Member
- Nov 2013
- Wakefield, NH
- 79
[QUOTE=JPEROG;2991091]Are you reading pressure from a gauge or smartcraft "which tells you what the computer is seeing"? its that or you are on the limiter.
autometer gauge, no smartcraft, I guess i'm pushing the limiter, thanks for you reply
09-30-2017, 05:44 AM #8Member
- Nov 2013
- Wakefield, NH
- 79
2000 Mercury 250efi loud constant alarm
By speedthriller in forum Technical DiscussionReplies: 5Last Post: 06-22-2016, 09:59 PM -
300xs - Temp Warning Alarm
By jpf091959 in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 13Last Post: 07-04-2015, 05:14 PM -
Mercury Tech: 1990 V200 Merc, constant alarm sound
By wbones9 in forum Technical DiscussionReplies: 31Last Post: 09-10-2014, 07:07 PM -
Mercury Tech: Help with constant alarm beeping
By Riverrat0 in forum Technical DiscussionReplies: 3Last Post: 07-21-2010, 07:33 AM -
300xs alarm
By kjenkins in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 5Last Post: 07-29-2009, 06:32 PM
