Results 31 to 34 of 34
11-26-2017, 09:38 AM #31
It could be cavitation but I would have that prop checked for a spun hub.
RockTeam Junk
Fishinmymission thanked for this postFishinmymission liked this post
11-26-2017, 11:09 AM #325000 RPM
- Jun 2017
- Connecticut
- 263
- 38
- 19
- 33
- 21
Thanks Rock I did not even consider that. I'll check for that. I think that ended up being it.
12-06-2017, 05:36 PM #335000 RPM
- Jun 2017
- Connecticut
- 263
- 38
- 19
- 33
- 21
I'm amazed with my new mercury blackmax 15x17" prop. The other 17" pitch prop was indeed spun I tossed it as its an aluminum prop with a rubber hub and figured its worthless for its price to press in a new hub. I gained about 350 RPM so I'm now at 5400 WOT and amazingly I picked up 6 MPH (39mph) by going down 2 inches pitch to the 17" pitch prop.
All this probably just further confirms that the engine was severly over propped, lugging, and outside of its powerband from running on the 19" pitch prop. Very likely that this caused the bearing and crank failures and possible even the gearcase that I blew 4 year prior.
The boat has been taken out for the year and I should be ready for some fishing come spring!
12-07-2017, 08:31 AM #34
I love a happy ending.
RockTeam Junk
Late 1995 mercury 2.5 260 power head minus ecu
By superboattwin250 in forum Misc. Parts and AccessoriesReplies: 1Last Post: 01-29-2017, 07:07 PM -
Photos: Skater Models, Options, and Specifications Sheets from 1995
By Scream And Fly in forum General Boating DiscussionReplies: 6Last Post: 12-31-2016, 09:59 AM -
Wanted: Power head for a 1995 3.0 225 efi
By knarloid in forum Engines WantedReplies: 5Last Post: 10-23-2016, 07:46 PM -
V-Bottom with pad 20'-22' 1995-2005 what are my options??
By 2SlowinTO in forum General Boating DiscussionReplies: 10Last Post: 10-21-2010, 07:34 PM -
Broke one head-bolt, when taking the engine apart...
By Hydro-T20 in forum Technical DiscussionReplies: 11Last Post: 12-21-2005, 05:12 AM
