Results 1 to 14 of 14
    Dec 2012
    tn
    What are symptons of a broken cranck sealing ring?
    What are the symptons of a broken crank sealing ring? I might have broken one assembling a 2.5. 1998 175 carb. It is acting up- throttles up to 1500- running rough- then will not go higher- dies when I push it EXCEPT if I hit enricher- it stumbles worse- but right after doing that I can get it over the 1500 rpm hump and it will wind up into 4000s or better- tests were done strapped on trailer with motor in the water so 4000 was about as far as I wanted to take- once over 1500 - runs smoother too.
    Checked spark at 1500 - good - and each cylinder dropped out when plug wire pulled- compression in 120s - correct carbs - timing checked and set-
    I am rechecking on lines and idle hoses-
    Not much. The symptom is the next time you pull the crank out the two pieces will fall on the floor.
    Baton Rouge, La
    I don't think it would cause your problem. Mike
    Cheaters never Win !!!
    Crap idle in gear low rpm , down on power.
    Nope
    Well, that's what I came across? I don't think I could say no problems? Wasn't the worst but idle low speed was crap.
    Aug 2011
    South Georgia
    We have 2.4 Efi with out 2 sealing rings for better lubrication on race motors.should not make much difference if any jmo.
    I just learned something.
    Aug 2015
    NE Tennessee
    Quote Originally Posted by timmc6 View Post
    Had a Merc rep ( friend ) give me similar "thoughts" back in the late 80's. I never tried it though. I was always a by the book kinda guy...back then anyway.
    Pekin, IL
    Leaving sealing rings out is fine in certain locations such as above center main bearings. I have done that on hot rod stuff for years. Reduces parasitic drag and allows better oiling of center mains yet sill seals cylinders from each other because of ring on other side of bearing. Your symptoms do sound an awful lot like those of an old inline with labyrinth seal issues. A broken ring would be a similar situation. I would also be concerned that without any tension the rings could be moving and possibly eating away the aluminum. Might be time to take that one apart again. JMO
    Rock
    Team Junk
    Dec 2012
    tn
    thanks Gents- I changed out stator and trigger last evening- going to go over fuel pump right now- failed to note here this is second set of carbs doing same thing- so I rule out carbs-
    I tried pumping bulb while at near bog - 1500 rpms - no effect at all and bulb was full- unless stator/triger swap fixes it- me think I have a vacuum leak somewhere-
    One odd thing I found when I tore it down- red RTV on exhaust divider gasket-
  12. #12
    Jun 2009
    central minnesota
    somewhere in the 80's cBush was driving a hydrostream at havasu race,omc dropped a powerhead off to us at Natuical Inn parking lot , with instructions DO NOT OPEN UP.. he and i took it into his cabanna ,i got my tools from my van, and in 45 min pulled c/case apart.crank rings were broken,don't remember if all were or not.He raced it two days later,steering broke----BUT boat was very fast-th
  13. #13
    Jun 2017
    fife scotland
    My crank seal rings are shot ( Engine rebuild this winter ) Johnson V4 85hp
    The mix on my motor should to be 50/1 pre-mix if i run this mix she will idle but not take any power at all. She wont get on plane and runs at tick over but noting else. Now if i run 25/1 she is like a new motor full RPM jumps out the hole no problem at all.
    I asked a OMC tech old school guy. He said she needs the extra oil to compensate for the leaking seals. Using this thicker mix is the ONLY way to make my motor run. I put 50/1 in her by mistake a couple of weeks ago and she would not run. I even asked here about why she wouldn't get on plane. I forgot my buddy was running 50/1 when i got some fuel from him.
    Just how my motor runs may help you till you get yours stripped down.
    I love my Bikini
  14. #14
    Dec 2012
    tn
    Trigger and stator did not help- But changing power packs and coil set did. Little hesitation when throttle is advanced then much power- pushed deck boat within 2 mph of fastest it has ever been- that was the good news
    When I got home I ran compression check 5 @120-130 with the 1 new piston at 105 - bored 20 over - WSM - maybe 2-3 hours run time - ok so maybe it come up when broken all the way-
    Then I did leak down -OMG- new piston was at 80% leak down- others in the 20s- Yikes- only a couple hours run time but I have never seen numbers that bad right after putting on back together- odd thing was how strong it ran- nearly matching a 200 2.5 I had on boat a while back-
  1. broken sealing ring???? also rebuilding..
    By Will I Am in forum Technical Discussion
    Last Post: 03-20-2007, 01:38 PM
  2. Sealing ring for a 2.0 L
    By dompie99 in forum Technical Discussion
    Last Post: 06-12-2006, 08:15 AM
  3. 280 with broken sealing rings
    By CCM in forum Technical Discussion
    Last Post: 05-22-2006, 08:57 AM
  4. Omc Sealing Ring?
    By rockfan in forum Props, Setup, and Rigging
    Last Post: 07-13-2004, 08:48 PM
