Page 2 of 2 FirstFirst 1 2
Results 16 to 27 of 27
    Jun 2002
    El Cajon CA.
    Quote Originally Posted by Brookbbb View Post
    Rough estimate on fix Eric?
    we can fix it for 150 if there are no other problems.
  2. #17
    Quote Originally Posted by Simon View Post
    Yes we can upgrade the 350 Verados . The upgrade depends on the year. We can go up to 450 on the newest motors.
    Details of what is done to achieve 450? All software or some hard parts involved?
  3. #18
    Jun 2002
    El Cajon CA.
    It is all software .
  4. Thanks AZMIDLYF thanked for this post
  5. #19
    Sep 2012
    Hi Eric. I had some 300xs's done by you few years back. Can you tell me what you can upgrade 2012 350sci's to? Plus what octane fuel do you have to run? Thanks.
  6. #20
    Nov 2013
    ca
    so, does this mean that you can increase the 400 to 450? or even a bit more? will a pulley change along with the software change result in more power? i tried to call you a couple of times, but the receptionist says you are busy.
  7. #21
    Jun 2002
    El Cajon CA.
    Quote Originally Posted by Turborr View Post
    The 350Sci's can be tuned to 390hp .
  8. #22
    Jun 2002
    El Cajon CA.
    Quote Originally Posted by conmax View Post
    We can tune the 400 to 450 without anything else done to the motor.
  9. #23
    Jun 2002
    El Cajon CA.
    Here is a link for more info on our option for flashing your ECU's.http://www.screamandfly.com/showthre...PCM-flash-tool
  10. #24
    Jun 2002
    El Cajon CA.
    Ttt
  11. #25
    Jul 2009
    Roseneath ontairo canada
    Hi Eric can you test the ecu’s from a 98 300 promax for problems ? It has both the fuel an ignition ecu’s.
    Trimmer & Pinner
  12. #26
    can you repair an early model ecu from a 1985 Mercury offshore updraft 2.4?
  13. #27
    Jan 2020
    Pinole, Ca
    Quote Originally Posted by buzmacdowell View Post
    If he can't then you would benefit from bolting a Bridgeport horn onto your engine and running the 11350A7 ecu. That is not too much money and much easier to find parts for.
  1. Merc 3L Performance Parts - Brucato / Simon / Taylor / Boyesen
    By aalbert in forum Misc. Parts and Accessories
    Last Post: 07-01-2017, 02:38 PM
  2. Simon Motorsports can repair all Mercury ECU's
    By Simon in forum Technical Discussion
    Last Post: 05-24-2016, 08:04 AM
  3. Mercury Tech: Simon Motorsports can repair most 2001 and newer ECU's
    Last Post: 09-01-2009, 08:25 PM
  4. Simon Motorsports can repair most 2001 and newer ECU's
    By Simon in forum General Boating Discussion
    Last Post: 11-10-2008, 08:57 PM
