Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 31
    May 2001
    great south bay
    Water Separator or Fuel filter?
    What is mercury recommending be used between tank and motor?
    Old spin on separator or a newer style sealed filter like mercruiser uses?
    May 2001
    great south bay
    Or Nothing?
    Try a 33093 Wix forget the high $$ Mercury filter , I have used them for 20 years , you will need to buy an adapter to adapt high pressure female to fuel barb but after you buy it once keep changing it out with purchase of $8.00 WIX ....
    Jay
    Jay @ JSRE
    Moline,Ill
    Wix 33482 has barbs on each end and I would run a fuel/water separator before pump and the wix after
    is gone
    May 2001
    great south bay
    Use a water Separator and filter or just filter?
    Central, PA
    You could get away with just the water separator as it will act as a fuel filter as well. I prefer just to have a fuel filter between the tank and my engines on all of my , they change out easy and still catch any water and debris
    Illinois
    Water separator first, then the inline high micron filter for the EFI like mercury sells.
  8. Likes Tom Foley liked this post
  9. #8
    Aug 2012
    Tenkiller Lake, OK
    I use Racor marine water separator/filters on my outboard 300 SX Skater. Mercury has conflicting recommendations about pre-filters on these motors. I did some additional research and found that Mercury does endorse pre-filters like the high flow Racor's for the 300SX's as optional rigging. They are the 660R models - 10 micron and 90 GPM. No chance of starving the frugal 300SX!
    http://www.parker.com/literature/Rac...ers_-_7702.pdf
  10. #9
    May 2001
    great south bay
    I have a problem with using 5/16" fuel line they are worried about filter flow?
  11. #10
    Jun 2001
    West Haven, CT
    I know this has been posted prev, always a good read - from Joe and Marty at Diamond Marine
    www.diamondmarine.com/web_pages/Fuel%20System.htm
  12. Likes Tom Foley, Bodhi, specboatops liked this post
    Jul 2002
    Copiague LI NY
    just put a decent 10 micron water separator in line, use 3/8" line and thats that...Every 250xs, 300xs 300X 300PM 250EFI i have rigged which are hundreds of them has had that set up and always been flawless...But running without a 10 micron water sep filter is asking for trouble especially with the **** fuel we have today...Had a customer with a brand new boat and the builder said NO WATER SEPARATOR...well i can tell you within 40 hrs the filter in the VST was clogged to **** and the motor wasnt running right....
    1984 28 ghost twin 200 Yamah ProVs (SOLD)
    1997 21 Superboat Legend 250 VMAXXX (SOLD)
    2001 25 Concept CC 250EFI (SOLD)
    2002 24 Superboat Step 250EFI (SOLD)
    1997 21 Checkmate Pulsare 200EFI Merc (Beater Boat)(SOLD)
    1994 20 Hydrasport 225 Optimax (SOLD)
    1998 27 progression Twin 225 Mercs (SOLD)
    2005 23 Kryptonite 300 Promax (SOLD)
  14. Likes Tom Foley liked this post
    May 2001
    great south bay
    Mercury Racing generated a service bulletin for the ProMax series motors prohibiting the use of hull mounted water separators.
  16. #13
    I've been using both a water separator and the Wix filter on 3 different 260s for 13 years and almost 500 hours with good results . FWIW .
  17. #14
    May 2001
    great south bay
    I have always used one but know it is a highly debated issue, Debate has begun!
  18. #15
    Jul 2002
    Copiague LI NY
    Mercury issued that bulletin like 20 years ago...lol...alot has changed...you run what you like but when **** gets in an opti fuel system it aint cheap to fix...
  1. Replies: 4
    Last Post: 11-19-2014, 07:38 PM
  2. Mercury Tech: fuel filter/water separator.
    By Mini GT in forum Technical Discussion
    Last Post: 04-03-2014, 11:32 PM
  3. New Fuel Filter and Water/Fuel Separator
    By tony97gt in forum Technical Discussion
    Last Post: 07-02-2012, 04:44 PM
  4. Fuel filter water separator
    By fmc1942 in forum Technical Discussion
    Last Post: 02-19-2010, 10:07 PM
  5. Replies: 16
    Last Post: 02-15-2008, 04:16 PM
