Results 1 to 8 of 8
09-19-2017, 12:06 AM #1Junior Member
- Aug 2017
- Kingston
- 21
Wanted 2004 70hp Johnson 4 stroke block
Well Guys I need your help Again,
I am looking for a 2004 Johnson 70hp 4 stroke block, Customer brought his in and has more water than oil going in the cylinders!!!
Let me know if anyone can help. he is a Military and just got deployed for 8 months so it's not a huge rush but if someone has something good I will take it.
Thank you all.You break them I fix it.
09-19-2017, 12:11 AM #2Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
Not sure but I think it is the same as suzikey motor . If so I have......
09-19-2017, 10:29 AM #3Junior Member
- Aug 2017
- Kingston
- 21
It is, what do you want for it?
09-22-2017, 06:12 PM #4Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
It is a 60hp 4 stroke. I can get # off the tag if that will help. I don't know price will ck with owner. $700 should do.
09-26-2017, 02:16 PM #5Junior Member
- Aug 2017
- Kingston
- 21
if you can get the tag as for some reason in the parts system the 60 is giving me a different block the 70 & 90 are the same or am I reading this wrong!!!
09-26-2017, 05:59 PM #6
The older blocks are different that the new ones....the 60/70 were the same blocks from late 90's till they changed designs I believe...will try to check it out tomorrow. The Johnson 4 strokes were made by Suzuki so are the same with the exception of the electrical plugs on the harnesses.
Hustler 15' Wildcat / Merc 80
Hustler 13' Wildcat / Merc 80
Hustler 13' Picklefork (Experimental) / Merc 80
Hustler 16' Victor / Evinrude 85
Hustler 15' Tunnel / Evinrude X115
Hustler 17' Lark / Suzuki 140
Ranger 17' Aztec / Merc 115
Hustler 16' Victor
Hustler 16' Victor / JohnRude 135 (current and restored)
Hustler 15' Family Tunnel / Johnson GT115 (current project)
Hustler 16' Victor
09-26-2017, 10:08 PM #7Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
Thanks Dan....
09-27-2017, 09:38 AM #8
The 60/70 blocks were the same from 98-03 then the part# changes for 04-09. The cyl heads also are the same from 98-03,04-06 and 07-09. In 2010 the 60 joined the 3 cyl 40/50/60 A series and the 70 changed to a 70/80/90 A series 4 cyl block.
Hustler 16' Victor
Hustler 16' Victor
Mercury Tech: help with wiring on 70hp merc 3 cyl 2 stroke...
By mitsugsx813 in forum Technical DiscussionReplies: 3Last Post: 05-07-2012, 02:07 PM -
4 stroke 70hp suz/evinrund
By seacow in forum Technical DiscussionReplies: 2Last Post: 05-17-2001, 08:41 PM
