Results 1 to 5 of 5
09-18-2017, 10:48 AM #1
Stuck jet on d2 johnson carbs removal help needed
I have tried to remove a bottom/main jet on my johnson v4 D2 carbs.
I had a screwdriver almost the same width as the "Homemade" jet removal tool that's on the web.
Problem is that the "almost" was not good enough now i have a stuck jet
Need help on trying to get this out. I dont have any easy outs small enough to get in.
I am very wary of drilling it but if it comes to it i will.
Is there a way to insert something in to the jet to remove it ???
Help guys
09-18-2017, 01:09 PM #2
A left handed screw is about the best thing next to an easy out.
09-18-2017, 11:55 PM #3Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
The square shank of a small hand file. Bang it in and it is hardened steel. Use some heat to help.
09-19-2017, 12:01 PM #4
that is a great idea, very similar to some new easy outs.
I will remember that one
09-19-2017, 08:20 PM #56000 RPM
- Calgary, Alberta
- 1,123
- 21
- 58
- 341
- 174
It may be worth investing in the correct tool for the job. 317002 is like $25, each wrecked jet costs about the same.
And yes to the heat - if water got into the float bowl the brass jet and pot metal bowl do not like each other from a galvanic perspective.
Matt
Gearhead needed 95 Johnson 225 Recirc Valve Removal??
By jstpie5 in forum Technical DiscussionReplies: 12Last Post: 01-07-2017, 11:02 PM -
Mercury 150 powerhead removal (stuck)
By ndf203 in forum Technical DiscussionReplies: 17Last Post: 06-12-2016, 04:12 PM -
OMC Tech: Older 75hp evinrude carbs vs 86' 70hp johnson carbs
By roycesrolls in forum Technical DiscussionReplies: 2Last Post: 06-01-2012, 08:24 PM -
OMC Tech: LU removal drive shaft stuck! Help
By sixmassive in forum Technical DiscussionReplies: 23Last Post: 10-25-2010, 10:12 PM -
1990 Johnson stuck @ 3000 rpm
By Streamin Along in forum Technical DiscussionReplies: 6Last Post: 03-18-2005, 09:36 AM
