Results 1 to 4 of 4
Thread: 300x wont idle
09-18-2017, 06:41 AM #1Member
- Jan 2015
- new hampshire
- 99
- 21
300x wont idle
I have 2 2005 300x the starboard keeps stalling when I pull it out of gear other than that it runs great, it will start back up the second you touch the key
. Any thoughts before I start checking things
Thank you
09-18-2017, 08:46 AM #2
Do you have access to a scanner? It could be something as simple as the neutral switch.
Just a little Cat.
24 Twister V8 E-Rude (For Sale)
2008 Concept Sport Deck 2x 300X
09-18-2017, 09:18 AM #3Member
- Jan 2015
- new hampshire
- 99
- 21
I do not but I believe there is no neutral switch, it will start in gear and it doesn't do it all the time
09-19-2017, 10:58 AM #4
There is a momentary switch that kills the ignition on a few cylinders to help shift in and out of gear. It is located on the shift linkage of the powerhead.
-93 Rude 120 wont idle
By Turbonito in forum Technical DiscussionReplies: 3Last Post: 07-22-2011, 10:10 PM -
yamaha 650 vstar wont idle
By baja200merk in forum Technical DiscussionReplies: 2Last Post: 08-24-2005, 01:35 PM -
60 deg v4 wont idle, whats up???
By chynewalkr in forum Technical DiscussionReplies: 2Last Post: 05-11-2005, 03:51 PM -
115 merc wont idle
By VectorPat in forum Technical DiscussionReplies: 2Last Post: 07-07-2002, 03:19 PM
