Results 1 to 15 of 18
09-17-2017, 05:53 PM #15000 RPM
- Dec 2012
- tn
- 686
- 17
- 46
fresh "build" on 175 2.5 - used 200 carbs - NO GO- and what is that d-mn beeping
1998 2.5 175 merc carb conversion from EFI- 1 new piston/bored 20+ others honed- 45 minute run time on hose and attempted lake run test-
compression 125 psi on old 5 - 120 psi on new piston- new rings can not be set yet- spark good when idling-
I used a set of WMV 18s (200 hp) stock jets - idle ok- at lake when attempting to throttle advanced - bogs out - can not seem to handle the fuel load-
Checked timing- was set at 18^ supposed to be 20^ - TDC set & .462 checked
Book says carbs should be WMV 4/4A for '98 newer ones have WMV 17
Are the 200 carbs just too much fuel?
and what is that damn beeping ? Getting a rapid beep from control box. Oiler removed, idle stabilizer removed, what I would normally call control module is listed as "Lubalert" on this model in book. I have several "control modules" if I should change it. I am sure something I did not hook up or should have hooked up is causing beep-
Converted from EFI to carbs-
ANYBODY GOT SOME 175 CARBS YOU WANT TO SELL?Last edited by CircleHook; 09-18-2017 at 06:03 AM.
09-18-2017, 07:50 AM #2
What size main jets? Mains that are too large will cause that kind of problem.
The jet size is more important than the kind of carb. A rejet is cheaper than a set of carbs.
. Mike.Last edited by tunnelmike; 09-18-2017 at 07:53 AM.
Cheaters never Win !!!
CircleHook thanked for this post
09-18-2017, 07:56 AM #35000 RPM
- Dec 2012
- tn
- 686
- 17
- 46
09-18-2017, 08:39 AM #4
Have you tried hitting the choke when it bogs to make sure it is not to lean, I know you think it's to rich but anything can cause a lean condition. I don't think a little rich would cause a bog unless the plugs are wet fouled. Did you try a quick rev in neutral then take off?
09-18-2017, 10:23 AM #55000 RPM
- Dec 2012
- tn
- 686
- 17
- 46
I did not try enricher- it will pull up to 1500/2000 ish under load - then bogs and dies-
I did try open throttle by hand at cam (no timing advance) - same effect but at much lower RPMs
Would low timing combined with too rich do it? Timing was at 18^ - suspose to be 20^
09-18-2017, 01:51 PM #65000 RPM
- Dec 2012
- tn
- 686
- 17
- 46
09-18-2017, 01:56 PM #7
Carbs are all different when it comes to jet sizes. I'm running 70s in a 91 14 petal200 that came with 66s from the previous owner in these wmv carbs that came factory on this motor. I raised the size for 34cc heads. Tried what turned out to be74s drilled out to 80 ish and that's what my Mirage did. When I would let off it would pick up rpm. If I eased into the throttle it was better but still off.
When I was drag racing a stock 2.4 with wh22s I ran 88 and 90 mains. I don't know why they are so different from the WMH carbs on main sizes but I'm slightly rich now at 70s
Try the enrichment trick , rich and lean act similar. MikeCheaters never Win !!!
09-19-2017, 06:51 AM #85000 RPM
- Dec 2012
- tn
- 686
- 17
- 46
Got a set WMV 4s on the way- when I get them on I will try enricher if still acting up
fixed beeping - though I have no idea what did it
09-19-2017, 08:35 AM #9
Hook, check the high output of the stator....that rpm range is where it comes in. Also take the lube alert module to the trash, no need for it if premixing.
Go Time
26 Regulator twin 250 EFI
W2F a V-King liked this post
09-19-2017, 08:36 AM #10
You using wmv carb plate ?
09-19-2017, 09:02 AM #115000 RPM
- Dec 2012
- tn
- 686
- 17
- 46
09-19-2017, 05:26 PM #12
Wmv plate 'vs wmh are different wmv has little notches for off idle
09-19-2017, 06:53 PM #135000 RPM
- Dec 2012
- tn
- 686
- 17
- 46
09-19-2017, 06:56 PM #145000 RPM
- Dec 2012
- tn
- 686
- 17
- 46
09-19-2017, 08:36 PM #15
wmv carb plate
pic of wmv carb plate
22t Liberator Boat Build With Single Mercury Racing 400R "NEMESIS"
By nemesis in forum General Boating DiscussionReplies: 13Last Post: 06-17-2017, 08:55 AM -
Build (Pic' Heavy) / My winter project "making a race boat more family friendly"
By Pachanga_rick in forum General Boating DiscussionReplies: 5Last Post: 04-03-2013, 01:52 PM -
Fresh thoughts, Sandy Brook kids, and long ago a "mass" murderer..
By Robby321 in forum The Scream And Fly LoungeReplies: 3Last Post: 12-18-2012, 03:57 PM -
While we build useless electric "rides", other countries, march on..
By Robby321 in forum The Scream And Fly LoungeReplies: 0Last Post: 02-15-2011, 09:49 PM
