Results 1 to 5 of 5
Thread: 60 to 70hp Jetting question
09-16-2017, 03:22 PM #1
Ive just swapped my 1992 60hp carbs for 1992 70hp carbs on my 56ci 3 cylinder Johnson, I rebuilt the engine due to a bad cylinder and bored all 3 cylinders .030, the book calls for 50D jets I believe for the 70 carbs, what would you increase the jet size to to make up for the .030 oversize in bore? I plan to set the timing at 19 degrees? Needing dependability out of this setup? Thanks guys....
1987 Vantage XT 200 Pro Max
1991 25 Liberator 300 xs's
1967-8-9 Z28 Camaro
1968 SS/RS Camaro Convertible
1969 SS 396 L89 Camaro
1970 440 6 pac GTX
14' jon boat 15 John-rude!
09-17-2017, 03:54 PM #2
what carbs have you got ? are they the old style or the black plastic top carbs ?
50D mains in old style with a 32 at the top.
if black top carbs they 50D at bottom and 55D at the top.
But you can go a lot bigger on the jets for high performance in the old style carbs.
what is the number of the 70hp carbs ?
04-25-2018, 10:59 PM #3
These are the old style carbs , 92 model, I ran it today and the 50D and the 32 are lean at cruise speed? Should i go with 54D or 56D mains? whats the D and the C mean on the jets? I don't know the number on the carbs , But Ill look?
1967-8-9 Z28 Camaro
1970 440 6 pac GTX
04-26-2018, 03:52 AM #4Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
c and d jets are flowed in opposite direction so you cant swap them
OMC's never have an issue with re jetting due to a rebore.Last edited by powerabout; 04-26-2018 at 09:51 AM.
racer liked this post
04-26-2018, 09:19 AM #5I may be slow but im ahead of you. *hit's only ankle deep but you went in head first.
OMC Tech: Another Jetting question.
By trickey in forum Technical DiscussionReplies: 11Last Post: 11-21-2009, 03:44 PM -
OMC Tech: 1988 Johnson 70hp Outboard question?
By Air Dog in forum Technical DiscussionReplies: 5Last Post: 10-19-2008, 09:55 AM -
Jetting Question for T-REX
By mach351 in forum Technical DiscussionReplies: 2Last Post: 08-22-2007, 08:16 PM -
3cyl Merc 70HP tech question
By lakerider8 in forum Technical DiscussionReplies: 3Last Post: 10-08-2006, 12:30 PM
