Results 1 to 8 of 8
Thread: 280 neutral safety switch
09-14-2017, 09:42 PM #15000 RPM
- May 2015
- Northern IL
- 188
- 10
- 60
Been having a bug with a 280. Everything on the motor and wiring tests out perfect, grounds, fuel pressure, compression, etc. the motor runs very rich and will not spin much past 5k. I noticed that one of the 2 wires that connects to the neutral safety switch is broken off at the switch.
my question is, how would a 280 run with one of the neutral safety switch wires disconnected?
09-14-2017, 10:01 PM #2
The switch on the shift bracket on the side of the motor?
09-14-2017, 10:11 PM #35000 RPM
- May 2015
- Northern IL
- 188
- 10
- 60
Yes sir
09-14-2017, 10:14 PM #4
That's the shift position switch, so the ecu knows whether it's in gear or neutral. If the wires broke the ecu will assume it's in gear and it will be hard to shift along with idling a couple hundred rpm high in neutral. The neutral safety switch is in the control box/shifter.
09-14-2017, 10:16 PM #55000 RPM
- May 2015
- Northern IL
- 188
- 10
- 60
Thanks for the info! Now I know that has nothing to do with the problems I am having haha. Was hoping that would be my fix
09-18-2017, 07:01 AM #6
If that switch isn't working properly it will cause all kinds of issues... more than most think. replace the switch
09-19-2017, 08:47 AM #7
Chummy is right. Rev limiter is different when computer thinks engine is in neutral. Think may also make shifting essier by momentary ignition interruption. And make sure you get the right one.
Go Time
26 Regulator twin 250 EFI
09-20-2017, 02:07 PM #8Registered User
- Sep 2010
- toronto, canada
- 236
- 10
- 17
- 80
Neutral safety switch
By tony brimeyer in forum Technical DiscussionReplies: 2Last Post: 03-26-2015, 01:13 PM -
Neutral safety switch or not?
By Gorilla0178 in forum Technical DiscussionReplies: 15Last Post: 12-14-2010, 02:04 AM -
Mercury Tech: Neutral safety switch
By fireedge11 in forum Technical DiscussionReplies: 4Last Post: 04-13-2010, 06:17 AM -
By fishead1 in forum Technical DiscussionReplies: 2Last Post: 02-11-2006, 02:15 PM -
By blkgixxer in forum Technical DiscussionReplies: 5Last Post: 01-12-2004, 06:08 PM
