Results 1 to 4 of 4
Thread: Help plug wires 220 mariner.
09-14-2017, 09:07 PM #15000 RPM
- Mar 2016
- Anza, CA
- 229
- 7
Is there a trick to changing plug wires on a 1987 220 mariner. I pulled one plug wire out of the coil but it doesn't look like the new wires I bought. It looks like the metal end is stuck in the coil. I tried removing it with some needle nose pliers but it wouldn't come out. Can someone help me?
09-15-2017, 10:30 AM #25000 RPM
- Mar 2016
- Anza, CA
- 229
- 7
Trying to make sure this thing is ready for the weekend do I need to change to new coils are the metal ends of the plug wires just stuck in the coils? It looks like there might be some glue or sealant.
09-15-2017, 10:59 AM #35000 RPM
- Jun 2009
- central minnesota
- 770
- 30
- 24
factory used some camel snot that is real sticky,just use small screwdriver to bend metal piece and pull out.clean hole and insert new wire with silicone grease and ready to go-th
Nielmcque thanked for this post
09-15-2017, 12:40 PM #45000 RPM
- Mar 2016
- Anza, CA
- 229
- 7
Thanks thats what I was hoping just didn't want to ruin it if I was wrong.
Msd plug wires
By bigbluechevy454 in forum Technical DiscussionReplies: 8Last Post: 08-26-2013, 06:46 PM -
NGK blue spark plug wires Resistor Wires?
By tdogcarter in forum Technical DiscussionReplies: 4Last Post: 02-09-2006, 07:30 AM -
plug wires
By Farmboy in forum Technical DiscussionReplies: 1Last Post: 06-04-2003, 02:22 PM
