Results 1 to 15 of 18
Thread: Issue with 2000 300 Pro max
09-14-2017, 01:51 PM #1Member
- Apr 2009
- Michigan
- 77
The tell tale on the port motor has gone weak. There is water running down the outside of the lower shroud at idle although water pressure gauge is showing 5 psi. Coming in from fishing the other day (at 4500 rpm) motor stumbled twice and there was a beep. I think it was trying to tell me overheat?
Can I have a leak in the water supply line and how tough is it to pull the lower shroud off these motors? Boat is in a lift.....
I took a video but it won't load.
Took upper cover off and started motor- no visible leaks at powerhead.
This is the same motor we replaced fuel pump on.... We have nicknamed port motor Clyde.....
Thanks guys.Last edited by wannabee; 09-14-2017 at 02:00 PM.
09-14-2017, 02:22 PM #2Member
- Apr 2009
- Michigan
- 77
OK painted up a Diagram. Yellow area is where water is coming down///
09-14-2017, 02:48 PM #3
Check the diaphragm on your poppet. When it ruptures you will have a leak there but usually the motor wont warm up. If its an alien cowl you have to take the skirt off. Easy job.
09-14-2017, 02:49 PM #4Member
- Apr 2009
- Michigan
- 77
Where is the poppet on these motors.
If you see where the diagram is there is no water leaking at the motor. I suspect the waterr supply line coming up from the LU.
How hard is the skirt to remove? 4 bolts? I am mechanically inclined so thats not the issue- hanging off the back of a Donzi 35 ZF is NOT EASY>
Thanks-Last edited by wannabee; 09-14-2017 at 02:54 PM.
09-14-2017, 02:57 PM #5
6 if they are all there. Starboard side under skirt.
09-14-2017, 02:59 PM #6
09-14-2017, 03:01 PM #7
09-14-2017, 03:24 PM #8Member
- Apr 2009
- Michigan
- 77
Could be from debris too. We have lots of weeds in the canal.
09-14-2017, 03:44 PM #9
Check the tell tail hose for a pebble or weeds.
09-14-2017, 04:00 PM #10Member
- Apr 2009
- Michigan
- 77
We have. I think the poppet is gone.... either diaphram or ?
09-14-2017, 04:37 PM #11
Have your wife blow out the pee hole.
09-14-2017, 05:25 PM #12
My guess is that your powerhead base gasket is blown. #4 in first diagram. Those motors have been bad about that. Mine blew several. Even torque is the key.
09-16-2017, 08:08 AM #13Member
- Apr 2009
- Michigan
- 77
So can I check the Poppet by taking the collar #48 off? Is it just some screws?
09-16-2017, 08:11 AM #14
Yes it is 6 I believe 1/4-20 screws. Locate poppet cover, remove two more screws and check diaphragm. While your there replace it anyway and the two gaskets. JMO
09-16-2017, 08:17 AM #15Member
- Apr 2009
- Michigan
- 77
Where do I find these? Finding a fuel pump was very tough!!!! Is this part common across several motors? Venemous if you have part #'s that would be great. Thanks
Mercury Tech: Dual temp gauges issue OR engine Issue
By dompie99 in forum Technical DiscussionReplies: 4Last Post: 05-24-2016, 09:37 AM -
250xs top cowl melting common issue or is there an internal issue I should look for
By 150aintenuff in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 0Last Post: 08-30-2015, 05:14 PM -
OMC Tech: 2000 Johnny 200 heat issue
By Glasstream15 in forum Technical DiscussionReplies: 4Last Post: 08-24-2014, 03:11 PM -
2000 Promax High Water Pressure Issue
By Big E in forum Technical DiscussionReplies: 9Last Post: 11-09-2009, 04:13 PM
